MarkE
Lift buckets of water.  Lower buckets of water.  Thump on a Bible.  Claim free energy.  Pimp worthless investments.  Any questions?
mondrasek
MarkE, I choose this diagram of a probable State 3.  Unless it is in a condition where the sum of the buoyant Forces on the pod and risers is negative, I can work with it.  If it is a correct final State 3, the sum of those buoyant Forces will be zero.  If it is incorrect and the sum of those buoyant Forces is a positive value, that would mean the lift distance would need to grow further, but we can still check to see what Energy is in the water columns as well as the Work that could have been performed due to the lift so far.  IF those two values sum to a greater Energy than was present in State 2, it concludes that Energy increased in the transition from State 2 to State 3.
For simplicity I will be using 1gram/cc for the Density of the water, and 9.81m/s2 for the acceleration of gravity.
mondrasek
Unfortunately this State 3 being checked is not going to work for us.  When summing the buoyant Forces on the pod and risers due to the water Head on each you arrive at a negative value.  So the ZED could never rise to the height that is displayed.  It would stop short of that lift where the sum of the buoyant Forces is zero.
The buoyant Force on the pod and riser is calculated:
Fb = (Water Head) * (Surface Area)
For the outer riser this would be calculated as Fb = (AR7 - AR6) * (pi * r2)
If the units of measure are kept always as cm, the result is simply cm3 (also known as cc).  With the Density of water at 1 gram/cm3 the result is also the buoyant Force in grams.
So for the outer riser this would be calculated as Fb = (2.2966 - 4.0351) * (pi * 2.22) = -26.4344 grams of Force.  This riser is negatively Buoyant and pushing down against the middle riser.
Calculate the others similarly and you get:
Buoyant Force from Outer Riser  = -26.4344 g
Buoyant Force from Middle Riser =    0.9191 g
Buoyant Force from Inner Riser   =  14.8938 g
Buoyant Force from the pod        =    7.1132 g
Total Buoyant Force                    =  -3.5083 g
The ZED could not rise to this condition.
MarkE, do you want to argue this point, make a correction, or should I choose a different State 3 to work with?
Quote from: mrwayne on March 08, 2014, 07:18:17 PM
Hello Mondrasek,
A "builder" just stopped by shook my hand and gave me a running Sterno motor!
He drove 80 miles!!!
I love it.
I will be surprised if Mark ever goes any further with you - he is smart and can surely see the obvious conclusion.
The dodging and diversions and demands, intentional omissions, premature assumptions, degrading comparatives, making self supporting claims, assumed ruler of the universe, and  8) 8)   are much like TK - but I am not yet convinced.
"removed text for poor taste"
Let me put back in what you "removed text for poor taste." Some of your "poor taste" is preserved in MarkE's quotation of your posts, you cannot edit that away.
QuoteI am glad he is helpful to some - but being a total urd isser - does not help anyone.
You called me a " urd isser " and I will put in the letters you omitted. T and K.
You, Wayne Travis, are an ignorant, disgusting buffoon.   You can remove, edit, whatever.... but the record stands and with that little slip of yours, you have done two things: You have revealed your true personality, the muck inside your filthy lying self-serving mind; and you have earned my eternal enmity.  No.... do not bother to apologize. You typed it, I and others saw it. You will get what you deserve in the end, honest Wayne Travis, and Someone a lot more powerful than I will be seeing to that.
Beware, gentle readers and analysts. Honest WAYNE TRAVIS is "checking you out".
He is using his vast well-paid network of lawyers and webmasters and private investigators to find out who you are, where you live, just what your "qualifications" are and just whatever he can find to use against you.
People have been accused of being "paid shills" on this website before.... but we've never, to my knowledge, encountered proof before.... until now. Wayne Travis has his paid shills posting on this forum, attempting to help promulgate his fraudulent program and his "Zero Energy Device".
