Silly question about capacitors
Started by dieter, February 14, 2014, 10:48:52 AM
MarkE
Quote from: Magluvin on February 14, 2014, 06:57:55 PM
Lets say we have 2 equal size air tanks, 1 filled to 300psi and the other with 0 psi.
We connect the 2 together with a hose and we open the valves on the tanks. We should end up with 150psi in each. But we lost 50% of the total energy stored the first 300psi tank by the simple transfer, expansion and equalization of the 2 tanks.  Now, each tank contains half of the total air pressure that was in the 300psi tank. How did we lose 50%? The total amount of air(electrical charge) is still there in the 2 tanks, but we lost pressure. ???
We lost it stupidly. ;)   It wasnt lost due to resistance. It wasnt lost due to air leaking out. We lost it by reducing the pressure that was in the first tank and expanding it into 2 cambers, each the size of the first full tank.
Now, if we had a pump motor that uses air pressure to provide mechanical output(turbine may be a bit lossy due to blow by of the turbine fan) and we connect the air motor inline with the hose between the 2 tanks(1 full, 1 empty), then we are capturing that lost 50%(or so) of the total energy of the first tank during the transfer. So now we are not losing that energy stupidly. ;)
And in the end, we still have 150 psi in each tank, just like when we transfer the pressure from 1 tank to the other directly without the air powered motor, but without the huge stupid loss. ;)
So I dont believe that resistance is the issue with losing 50% of the initial energy of the full tank equalizing to the second tank.  Its just the fact that we reduced the energy of 300psi air pressure of 1 tank and expanded it into a tank that is twice as large, without doing anything with the actions of the transfer. And once the 2 tanks are equalized, there is no way that the 2 tanks of 150psi can be used to compress the total amount of air back into 1 tank at 300psi. But, if we mounted a large flywheel to the air motor, the energy that was lost in in the direct connect example is stored in the flywheel, and once the 2 tanks become equal(150psi), the flywheel is fully charged and would continue to pump the originally empty tank, pretty close to what was in the originally full tank, minus losses in the mechanical motor and resistances of the air being pushed through the hoses and fittings, etc.
Now with the caps, we can use an inductor as the air motor and get most all the energy of the full cap into the empty cap. Using a diode(check valve) to keep the previously empty cap, now nearly full, from going back to the first tank. ;) A bit of loss in the diode due to voltage drop inherent in the diode.
Mags
Magluvin, what you propose will not fix the problem.  If we were to scale the capacitors or tanks so that they are not equal then we can greatly improve the efficiency going one way.  That is how charge pump power converters operate with relatively good efficiency for small loads.
Farmhand
There is no loss of "charge".
Did no one look at the "Charge" in "Coulombs", If we take 2 x 10 000 uF capacitors and we have one at 16 volts the electronics assistant tells me it has 160 Millicoulombs of charge.
Now if I was to connect the two caps together and equalize the charge which results in both having 8 volts across them then the electronics assistant tells me they will both have 80 Millicoulombs of "charge" in them so added together there is still 160 Millicoulombs of charge, so no loss.. Where is the loss. The energy in a capacitor is really only "potential energy". I think the capacitor actually stores "charge", not "energy".
The voltage increase on a capacitor has a non linear effect on the "potential energy". meaning from 0 to 8 volts is less "potential energy" than from 8 volts to 16 volts, the voltage increase is the same but the potential energy increase is not.
Cheers
Magluvin
Quote from: MarkE on February 14, 2014, 09:23:26 PM
Hey Mark
What problem are we talking about?  I thought the issue was described in the first post about the 50% loss when connecting a full cap to an empty cap. ;)   From what I understand, the size difference in caps still have losses due to the same issues, just different ratios of losses depending on the size differences in capacitors used. Like if we had a 10uf cap with 1000v and dumped it into a 10,000uf cap, the loss would be huge and beyond 50%, but the other way around the loss would be less. ;) What I am claiming is, I dont believe that the loss from cap to cap directly is related to resistance losses during direct transfer.  What hit me hard when I first encountered this problem was the fact that there is a 50% loss, no matter what the resistance is, whether it be high resistance or extremely low resistance, the loss is the same. It seems odd, no?  For some reason, resistance is the claimed cause of the loss, but there is no variance in loss with different values of resistance. Where in other circuitry, there is a difference when there is a difference. ;)
For example, say we have 2 caps that had no resistance, zero resistance, zero losses of any kind. When we connect them, one charged and one empty, and lets get rid of inductance for this for now to eliminate oscillations,  do you believe that when we discharge a 100uf cap with 100v into an empty 100uf cap, that there would be more than 50v in each cap????? ;)
Gota go pick up my pizza.
Mags
MarkE
Quote from: Magluvin on February 14, 2014, 09:47:11 PM
Hey Mark
Mags
Magluvin, take a 100uF cap.  Charge it to 10V.  Connect that to a 1uF cap.  Calculate the net energy.  It is close to the original.  The worst case is always when the capacitors are the same value.
Marsing
Quote from: Farmhand on February 14, 2014, 09:40:59 PM
ok,  but you need energy to put back  only one cap  full of charge
the lose here is about to back to first condition.
btw, tesla have a great way to take advantages of this
