Recover energy from gravity
Started by rc4, February 15, 2014, 05:21:41 AM
rc4
The fixed grey tube increase height of water, so increase pressure at bottom. External pressure don't change lateral force because grey tube is at right and at left. Inside container, at bottom there is more right force than left but this depend of the diameter of the tube, like tube has more volume inside water, the height of water is greater. Weight=f(h) but Fr-Fl=f(h'). Grey shape is a helix, the length of helix is greater than a triangle so the volume is greater too and the weight too. In the contrary, the right force is the same than a triangle.
Look at h2.png image, s1 and s2 sections are the same and the volume is the same too, so the same weight for container. But with a helix shape, the section is the same than the triangle but the volume is higher, it depend of 2pi. The limit is 0.63 (4R/6piR). Helix don't turn, don't move, it is there only for adding volume inside container, like that the weight is higher and the right force is always equal to the triangle, so the container give more energy than its own weight.
rc4
I compute the works for additional weight and F1-Fr force. With:
N: number of turns
S: section of helix (the section of the cable)
a: angle of axis of helix
P: pitch of helix
g: acceleration of gravity
rho: density
R: radius of helix
Gabriele
Or I'am stupid a lot,or you are a fucking GENIUS!
Gabriele
You have to make the container turn to gain energy... :)
Gabriele
