Acoustic magnetic generator.
Started by synchro1, February 15, 2014, 06:07:02 PM
synchro1
Here's a new related topic:
http://www.free-energy-info.co.uk/PatD9.pdf
"Claim 1:
An acoustic magnetic power generator composed of an alternating current signal generator connected to an acoustic transducer which stimulates the core of a permanent magnet such that the atoms of the magnet are caused to vibrate which in turn causes the magnetic field to vibrate and causes a current and voltage to be generated in an output coil wrapped around a permanent magnet or in the magnetic field of the permanent magnet which said current and voltage can be used for powering a load".
Here's a copy of the "Full Patent":
http://www.google.com/patents/US5568005
Danial Nunez has demonstrated how he sends a "Quick and Dirty" audio signal from his I-Pod App, through an amplifier into a Rodin coil. One could use the very simple and low cost Nunez approach to stimulate a smoke detector type Piezo Transducer attached to the magnet core of a "Synchro Coil" with a resonant LC tank and diode. One could easily get the kind of overunity effect described in the "Self acceleration Reed switch thread" that Conradelektro failed to follow through with. This approach is sure fire and wouldn't require any difficult neutral zone positioning of the coil!
More useful gouge:
http://scraw.hubpages.com/hub/Economical-Benefits-of-Free-Energy-For-A-Cab-Driver
"It is possible to produce anywhere from 1mA all the way up to 5 Amps".
"Coil Wire
The best way tap into eletrical current from the power generator is to wrap copper wire around the permanent magnet. Any size will suffice, however the number of turns will determine the amound of current and voltage. The load will be connected to the wire terminals, which will need to be connected with a fuse to provide safety in the event of voltage spikes".
A variable capacitor, or "Radio Tuner" wired to the "Synchro Coil" would help tune the LC resonant frequency to the acoustic sine wave.  Amplifier volume would help control power.
Here's what a 20 to 20khz audio piezo transducer looks like below: This would simply attach to the magnet core!
synchro1
Here's a good article on the MRA or "Magnetic Resonance Amplifier" of Joel McClain and Norman Wootan:
http://rexresearch.com/mra/1mra.htm
Concerning resonance:
"The MRA is a series resonant LC circuit in which power gain is attainable as a result of the increase in effective impedance under certain operating conditions. When the series impedance increases, primary current is reduced. When the power available from the secondary coil either remains the same or increases as the primary circuit impedance increases, a power gain occurs".
"In application, the MRA is tuned at resonance for maximum power transfer, then detuned slightly for maximum power gain. This relates directly to the use of thermal pressure at resonance, and the effect that this has on continued polar rotation and the release of donor electrons".
synchro1
One can see how fiendishly simple the MRA circuit is. McClain and Wootan simply wrapped one end of the piezo wire around the magnet. They called the piezo chip a capacitor and the wire the inductor of an LC tank. Then there's a secondary to a full wave rectifier, and the D.C. load. They were denied a patent for this overly simplistic circuit. The Davidson patent US 5568005 A merely vibrates the magnet core with the transducer. My version is similar to the Davidson patent but includes a separate tank to tune the coil.
magpwr
Quote from: synchro1 on February 15, 2014, 07:53:10 PM
hi synchro1,
I have tested the "barium titanate" which was purchased off ebay.
But without the "Barium ferrite magnet" i'm only able to achieve 500uA at 10volt  of output power (OU) for 1uA(input current) using 5volt input connected via 1kohm resistor in series with Barium titanate running at 16.8KHZ for a specimen /fragment.
Instead of Barium ferrite magnet i was using bilfilar consisting of around 45 turns 18AWG on 3 toroid.There is around 2.2x voltage amplification at around 10..13 volts output but output current is mere 500uA.
There isn't enough power to support even my low power microprocessor which needs 500uA at 2v but i'm unable to get the required frequency which need 5volts.
The objective was to create a loop back the easy way.Unless someone knows maybe a "watch circuit which draw ultra low power for the signal generator" maybe i can do it and still light a led (forever) at least.
It's so hard get Barium ferrite magnet.The only source i know is China.
The last round of barium ferrite magnet (custom order) shippment to my home was a disaster at 45kg they can't shipped out via Air due magnetic field which was too strong even after using metal box.I know nuts about using ships for delivery suggesting for fedex or ups or etc did not give me any result.
But at least they gave me a refund minus  the production cost of USD100."$#%^"
As the site claims it will only gives few watt of power which is good enough for me for a start and use it to smack skeptics in the face. :)
synchro1
@magpwr,
Permanent Magnets:
Permanent magnets are manmade materials that produce their own magnetic fields. They can attract ferromagntic materials, such as iron, nickel or cobalt. The magnets are made from "hard" ferromagnetic materials such as alnico and ferrite. Engineers use special processing techniques that utilize powerful magnetic fields. This process aligns the internal microcrystalline structure of them, so that they never get demagnetized. Those motivated enough to experiemnt will not have to concern thelmselves with various sizes or magnetic flux. The acoustic-magnetic generator will work with any of them.
The "Acoustic Magnet Generator" or AMG is not the MRA, or "Magnetic Resonance Amplifier", which calls for the Barium Ferrite Magnet! Try the AMG and some Neo's! The Piezo transducer does not make contact with the magnet in the MRA, unlike the AMG!
