Acoustic magnetic generator.
Started by synchro1, February 15, 2014, 06:07:02 PM
Turbo
So like i said in my last post you work towards the source of energy.
This means you take a look at the mechanism that creates these electromagnetic waves and what source is responsible for their existence.
By carefully studying this mechanism and by understanding it you then ask yourself the question what else can we do with this or how can we use it to our advantages by for example changing certain parameters and regenerating the effect on a small scale basis to see what results you get.
Once you understand the mechanism and how exactly these waves are formed but most importantly where the energy comes from you can then easily see how short visioned some people actually are in the sense of saying no nothing there mostly without actually even looking at it and making all kind of false pre consumptions and wrong conclusions that show where the real dead end is.
Just ignore these people as they are of no use to us, and keep in mind that there is a lot of energy available, and then try to understand, tweak, re-create, and use the mechanism for your advantage and you will be fine.
verpies
Quote from: MileHigh on March 02, 2014, 09:32:33 PM
Can you do anything practical with this on the bench?
I can get the acoustic effects to influence the resonance of a simple LCR circuit and obtain similar effects to this and this and this.
I was never able to get my acoustic frequency up high enough to observe NAR in a magnet.  You are correct that any inducted spin precession will decay in T1 time specific to the resonating material and field inhomogeneities will cause rapid dephasing (T2).
Is this in any way related to Synchro1's fantasy about resonance and magnets?
I don't think so, but then I don't really understand what device he is proposing.
synchro1
"Verpies,
The device I am proposing I already built and tested. It charged the run battery looped back to source. It is simply a magnet core solenoid output coil. The stack of core magnets was diametricly polarized neo tubes, connected end to end. The coil was copper wire wrapped bifilar and series conected. A capacitor was connected in sereis with the coil and a Shottky diode. The capacitor and the coil were matched to créate a series resonant LC tank with a resonant frequency of 7.8 hrz. The diametric spinner RPM was in resonance at around 1000. This caused the amplified oscillation witnessed in the satellite magnets in the Jerry Bayle videos. My magnets were stationary inside the coil core, but of course the flux fluttered with the resonant agitation.
Watch the increased oscillation of the satellite magnets in the Bayles video as he decellerates his rotor into the resonant range of 7.8 hrz. I call this A vector potential magnet core coil the Synchro Coil. Conradelectro started building one and was side tracked by Milehigh when he repalced the capacitor with resistors.
Baylews demonstrates the increased oscillation of his satillite balancing magnets as he powers down into the resonant range, showing the inverse energy to power ratio. The idea is to capture this increased satellite power with output coils. Notice the 90 degree axial relationship between the diametric disks and the spinning satellite.
Imagine Lidmotors Maggie with a neo sphere in the output coil and a bearing  axeled horizontal diametric neo tube spinner for prime mover. Placing the output coil so the wire faced the spinner would not cause Lenz drag from the prime mover, but the satillite neo sphere flux would be cutting the output coil wraps at 90 degrees spinning the upright sphere on its vertical axis. The idea is to spin at resonat 7.8 hrz or 936 RPM where the satillite oscillation is maximized.
Turbo:
QuoteThis means you take a look at the mechanism that creates these electromagnetic waves and what source is responsible for their existence.
You notice I didn't even mention anything about any mechanism that creates electromagnetic waves.  That's called leading yourself down a garden path.
QuoteOnce you understand the mechanism and how exactly these waves are formed but most importantly where the energy comes from you can then easily see how short visioned some people actually are in the sense of saying no nothing there mostly without actually even looking at it and making all kind of false pre consumptions and wrong conclusions that show where the real dead end is.
I suggest that you use Google.  I looked this stuff up a few times.  A subset of the EM spectral energy from a lightning bolt discharge will fall into the range of wavelengths where the Schumann cavity will reflect them.  I will take a wild guess that 0.01% of the radiated EM energy in a lightning bolt will get reflected.  Since the Schumann cavity is a lossy reflective cavity, perhaps within a few seconds all of the reflecting energy is lost - the lost energy ends up heating the surface of the Earth and the ionosphere.  The amount of heat added per lighting strike relative to the thermal mass of the Earth and the ionosphere is akin to putting a single drop of water into the Pacific ocean.  There are something like 1000 lighting strikes per second over the entire surface of the Earth.
So you get incoherent "lossy ringing" in the Schumann cavity.  The amount of EM radiation in the air due to the Schumann ringing is insignificant.  It's like trying to see a lit LED on the surface of the Moon.
What is the power source for all of this you ask?  The power source is the Sun.  What powers the Sun?  Fusing hydrogen into helium.
Now, are my guesstimates of the relative scales of things truly accurate?  Probably not that accurate. but accurate enough for the purposes of this discussion.
The skinny:  The sun shines, that causes lighting strikes, and a tiny fraction of EM energy due to the lighting strikes will "ring" in the lossy Schumann cavity that envelopes the Earth.
The EM energy density in the air due to the lossy Schumann ringing is so tiny as to barely be detectable.  When you pulse a coil on your bench, the energy that is reflected back to you might be ten to the power of minus 50 relative to the original source energy.   That is a fantastically small number.  It's so small that you will never ever be able to detect it.
So there is your magical Schumann resonance.  It has ZERO affect on anything in practical daily life.  Scientists have probably done experiments where they transmit a powerful burst of EM energy at the optimum wavelength at the Schumann cavity and then the listen for the echo.  Because they are beaming a large amount of energy and they have very sensitive listening instruments they can "hear" about five or six echos before all of the energy is lost because the Schumann cavity is lossy.
Now for sure I might not be 100% accurate in my overall description - go to Google.  But the essence of what I am saying is true.  When I say that it's nonsense to fantasize about Schumann resonance effects on your bench that's true.
Bruce_TPU
Hi Turbo,
Good to see you back here for a bit.
Trying to convince Mile High of anything including the size of his ego is useless.   So it is best to ignore him.
He never listens nor experiments.  A waste of your energy.
Just trying to save you the headache. ..lol
Take care and let's compare notes again soon.
kind regards,
Bruce
