Acoustic magnetic generator.
Started by synchro1, February 15, 2014, 06:07:02 PM
synchro1
@Turbo,
Have you done any further tests?
Turbo
You mean on the magnetic thing?
No because i realized it was mechanical and will have lots of mechanical resistance and will eventually wear down so i switched research into more electrical means or solid state so to speak.
I did find correlations between neuroscience and this dancing magnet experiment i found that this 7.8Hz wave also seems to resonate with all living things on this planet and shows up on an brainwave E.E.G but that is also an entirely different area of research.
My final take was that telepathy must be based on something like the brain plucking magnetic field lines so we are all connected because we all live in the same magnetic field magnetic phone lines? no but i stopped magnetic research at that point.
I started to look at the mechanism that generates these magnetic waves which is lightning and lightning is generated by moving over a high voltage threshold so a strike occurs giving birth to the Schumann waves converting the DC ionospheric charge into alternating electromagnetic waves of a frequency related to dimensions involved.
Once i realized that this mechanism could be used in scaled down bench version to generate electromagnetic waves in a tweaked version of this exact mechanism things got interesting.
The tweaking involves upping the product frequency like Schumann waves on steroids so it matches a HF resonant circuit to extract the energy as well as the means of generating the event by pulsing high voltage in stead of going over a threshold which happens in the natural example.
But that was long after i was using single and slow mechanical generated high voltage pulses and using one way shots and diodes to extract the response and force it through a load to generate current.
I can not write 10 yrs of research into a single post and as you can see this has got nothing to do with the magnetic acoustic thingy.
ramset
Thank you for that post!!
This touches everything...............
Chet
Thanks Grandma
synchro1
Quote from Bayles:
"Proof that free energy is obtained through "wobbulation" around the axis of a spinning magnet where the wobbling is 90 degrees to the magnetic field. The result is a changing energy field axial within a hollow pickup coil that is 90 degrees to the magnetic field but inline axially to the wobbulation offset. A coaxial capacitor in the coil is used to pick up the radial electric field and the presence of that field proves the concept of a three dimensional 90 degree field change which is accomplished via the action of the spinning magnet wobbling towards the pickup coil".
What appears to be an inscrutable explanation here is really simple to decode. Bayles's spinning axial polarized disk magnet is wobbling slightly on the axle, and the output coil is placed sideways. The spinning disk's magnetic field is stationary in the direction of spin, but shifting side to side generating a current in the air core output coil at 90 degrees. This field shift is a fluctuating effect that Bayles has oscillating at a resonant frequency. He maintains there's free energy at  7.8 hrz resonance. This is a sine wave, and at 90 degress no different then the fluctuating effect of a spinning diametric.
Synchro1:
I am not aware of any applications associated with a "resonant frequency" for a magnet.  Verpies explained a method on the atomic level for very high frequency resonance of atomic dipoles.  I bet you weren't even aware of that, and for me it never even occurred to me but the reasoning makes sense.
None the less, it is somewhat esoteric and if there are any real-world practical applications it would be interesting to learn about them.
For whatever project you want to pursue, it still comes down to power-in and power-out measurements.  If you are a keener, you will draw up timing diagrams.  Wouldn't it be nice to see where the magic extra slice of apple pie appears right on the timing diagram itself.
The 7.8 Hz stuff and the line "The exciting feature in common here is the extra energy released from magnets at resonant frequencies." is just fantasy talk.  You are welcome to prove me wrong.
QuoteThe interesting link here is that McLain and Wooten got Barrium Ferrite magnets to ring at 8khz
Sorry I haven't looked at the link but I am smelling something amiss.  If magnetic molecules mechanically resonate in the megahertz frequency range, resonance at 8 kHz seems way too far fetched.  If you lower the intensity of the magnetic field inside a magnet, then the resonant frequency drops.  I simply don't ever see it getting that low.
However, if they are talking about the acoustic mechanical resonance of the physical magnet itself that makes perfect sense.  But then you are back to battling with Mother Nature:  If the mechanical resonance affects the magnetic domains resulting in the ability to extract power from a coil wrapped around the magnet, how much mechanical power do you have to put in to get the physical magnet to mechanically resonate vs how much electrical power can you extract from the coil.  There won't be an extra slice of apple pie there either.  Certainly experiment if you want to but those are some of the constraints you will find yourself under if you do the experiments and make proper measurements.
