Acoustic magnetic generator.
Started by synchro1, February 15, 2014, 06:07:02 PM
synchro1
Quote from: TinselKoala on February 17, 2014, 02:21:51 PM
Since many years, I make a practice of going for at least two days a week without driving or using any kind of petrol-powered vehicle. So... "when you pass, thank me for your gas".
Twisted bias is one thing, making false claims is another. My alleged bias has nothing to do with the _fact_ that I support my contentions with data, repeatable demonstrations that anyone can do, and checkable and reliable outside references.
I have two words for your over amped power hog transformer: "Short Circuit"!
Wrong again. You have been wrong many many times about my demonstrations, why stop now?
More:
http://www.youtube.com/watch?v=asM3Xj_O2Cs
Quote from: synchro1 on February 17, 2014, 04:12:27 PM
Wrong, and easy to refute as well. A Short Circuit has very low resistance to DC current, right? But my primary always has either the two 100 nF capacitors in series, or the piezo element in series ... neither of which pass DC current. Therefore... you are Yet Again wrong in your assertions about what my work demonstrates. Furthermore, the coil primary alone has a measurable, significant inductance. What does this mean as far as its ability to pass AC signals of high frequency? Do you know? I do.
synchro1
@Tinselkoala,
A short circuit is an abnormal connection between two nodes of an electric circuit intended to be at different voltages. This results in an excessive electric current/overcurrent limited only by the Thévenin equivalent resistance of the rest of the network and potentially causes circuit damage, overheating, fire or explosion. Although usually the result of a fault, there are cases where short circuits are caused intentionally, for example, for the purpose of voltage-sensing crowbar circuit protectors.
You found a way to bypass the transducer; Brilliant adaptation for an acoustic amplifier! You also grossed Jimboot off the Website. All you proved in the end was that you failed to get it to work to begin with!
verpies
Quote from: TinselKoala on February 17, 2014, 06:30:48 AM
Except that the piezo acts like a capacitor, therefore there is indeed an "LC tank" involved.
Yes, a piezo element acts as a capacitor and will form an LC tank with an inductor.
This is elementary.
