Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
@Lumen
Can you give us details.
Which magnets were used.. type and dimensions.
What were the magnet orientations.
What degrees of rotation for RO magnet from parallel to 90 off.
SL maximum and minimum distances from SL were.
graphs and so on.
                            Thanks floor
lumen
Quote from: Floor on September 22, 2016, 03:16:52 PM
@Lumen
graphs and so on.
                            Thanks floor
I will put it together so it's easy to understand, plus it would be good if someone else went through the data and calculated the result also to make sure us old guys didn't forget something.  :o
I found another scale that would work really well with collecting forces on my CNC machine.
It can take readings and save the data using an external input switch.
So I could have the machine make moves and it could instruct the scale when to save the data.
That means that I could map all data points over the RO rotation at every step/distance along the SL.
Wow, that kind of gives me a headache.
Floor
@lumen
Believe me, I understand that these measurements sets turn into a lot of numbers.
My measurements  have all been done by hand.
Do what you can as you can.
But please let us know the basics at this point
12% ... understood.
But which magnet alignments were they ?
Lumens X  ie pole to pole ?
       or
floors X   ie Polar edges to Polar edges ?
                 thanks
                      floor
lumen
So here are the results that I calculated to have a gain of about 12% excess output over input.
I tried to make it easy with all steps including the rotation move to be .05"
You can see from the negative number in the data, that near the end of the sequence the magnets pull together.
The magnets at their zero spacing have about .03" gap in all the tests.
I also added a short animation of the entire sequence.
Floor
Thanks Lumen
sumthun to  study  contemplate
            floor
