Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
@ Luc
Thank you for having given the diligence to examine the PDF docs.
The new test unit build is not yet finished. My limited and some what
primative shop space slow the process (lots of hand work).
I am in the process of building the "RO" (rotating) module.
Next will be a large dial indicator for attaching to the SL (sliding) module.
This dial indicator will be a separate module. The separation will eliminate
certain inaccuracies caused by the stretching of the SL weight string, while it is
under the influence of the heavier weight increment objects.
I could at this time, do a video of the original unit, if that will suffice ? That device
is in need of only some minor maintenance.
I could breifly demonstrate the "motion only", by first installing the mid range and then
the heaviest of  the weight objects (first SL then RO while SL is near RO).
Note... such a demonstration will potentially be misleading to viewers not
understanding the details of the measuring device / process.  As, both the input
and the output must occur along a "force curve" in order that work can be
cyclically done,
                    Again best wishes
                            floor
gotoluc
Thanks again for your reply Floor.
I would think your first test device would be fine for visually seeing the operation and effect.
If you're okay with making a quick and simple video demo I'm sure many would appreciate it.
It may also get others to experiment with the concept as well.
Thanks for your time and sharing
Luc
Floor
@ Luc
Thanks for sugesting a video, Will do.
I could use a break from the new build any way.
              floor
Floor
@ Luc
I made a 5 min. vid... It came out Ok. But when I went to upload, it was very slow / upload failed, twice.
This gave me pause to reconsider the (value to the project) and the (value to  other researchers)
of posting  the video.
I'm interested at this point, in PR as in pear review, not PR as in public relations.
9,000 views....  585 downloads of the first doc.  What percentage of those 585  read and
understand the measurement made ??? ... I could only speculate.
VALID observations and criticisms and or clearly stated questions are more valuable to me
than large numbers of views or praise at this time, although the latter is also greatly appreciated.
Bottom line,, I'm not posting the video link at this time.
                      Thanks for your time and interest
                          best wishes
                                     floor
gotoluc
Thanks Floor for considering a video demo.
All the best in your experiments
Luc
