VORTEX COIL FRAMES/FORMERS FOR SALE ...
Started by Electronix Hive, February 17, 2014, 03:23:30 PM
Surprise!  I was an electrical engineer.
The reason I went back to the forum was to find a clip for Farmhand to help him with his replication.  You may have linked to it earlier but I think you went back and edited it out.
Here is the MrWarrensk clip:
http://www.youtube.com/watch?v=IfPbiOYdd7U
Farmhand if you look around on MrWarrnsk's channel you might find a better clip.  My suspicion is that the 1:1 vortex coil with a high voltage output on the secondary happens because the circuit resembles an ignition coil circuit.  The 1:1 air coil primary drive circuit shuts off quickly and the magnetic energy then discharges into a high impedance load connected to the secondary.
It is a genuine amateur clip from a beginner where he makes reference to resonance and increased amplitude or "energy gain."  His scope is on "chop" which is somewhat annoying but that's fine, all part of the leaning curve.
Electronix Hive
Milehi ...
cheers for the info good to learn from all people. like i said i know these ain't no magic device...just interesting what they do and way to expensive from other sellers.....well the links are their if anyone wants to try or now....must put a close to this now getting long ...and making my hair grey lol
but i will say if anyone reading this does try these type of coils...whether it be cone/ vortex panacke and finds that some of the comments are wrong or even right on both sides they post it as i'm all for progression
Cheers, perhaps Farmhand will buy your vortex coil formers for his test, you never know!
carbon sugar
hola como andan? vengo aca para aclarar algunas cosas, la sobre unidad es totalmente accesible para cualquiera, bobina 3 (250 vueltas CCW), en el mismo nucleo ponemos una bobina 2 (250vueltas CW), y una bobina primaria de 14 vueltas CW, osea la 1 y 2 CW y la 3 CCW, a eso metiendole con un generador de señal, a un mosfet driver canal N, tira cerca de 5kv aproximadamente, con un ingreso de no mas de 70voltios
