Gravity seems to yield unequal results.
Started by isodecryptor, February 18, 2014, 05:10:09 AM
isodecryptor
if you would like the best results for a simple setup, make the outside weights equal to the middle weight, and expect no more than a theta of 45 degrees in respect to the height.
isodecryptor
I have some strange results in my simulation for physion. I used the same weights on middle and outsides, a rolling circle and two springs that are holding the on the outside to the ground. I am not sure how realistic this software is but it is moving perpetually. I dont think it is trickery, or at least I hope not!, otherwise, it is very interesting and I am going to post it now. NO motors are in this system and all settings were on default. I re ran the simulation several times and the results came back to this perpetual movement. At least it is very interesting and worth taking a look. I will upload the file so you can have a look. I really hope the springs have some realistic calculations in there.
https://www.mediafire.com/?dk97mbnc9n3bdv5
isodecryptor
I have changed the spring constants k to many different values and it still remains in perpetual motion. What could this software not be calculating. There is the spring constants, elasticity, and friction.
isodecryptor
Here it is with the higher spring constant of 50. It works with the other but very slowly. https://www.mediafire.com/?dk97mbnc9n3bdv5
isodecryptor
Here is another one using just springs instead of outside weights! I really think that they need to update their software or I have an idea why it is doing this. I really think their is another force that is assisting this setup. The cscx has strange asymptotic behavior and springs force change with it. .  https://www.mediafire.com/?dk97mbnc9n3bdv5
