Motor-Generator
Started by Miroslav13, February 26, 2014, 02:21:32 AM
gotoluc
Quote from: gyulasun on March 23, 2014, 02:01:12 PM
Luc,
sorry to ask, did you mean it made "NO difference" ?  You wrote "on difference" which was also translated to Russian as "it made a difference"...
Gyula
Yes, "NO difference"
Thanks for catching that!... I edited the reply
So you can you read Russian?
Luc
yssuraxu_697
Quote from: gotoluc on March 23, 2014, 01:34:31 PM
3256uH @ 60630Hz
2.45 Ohms RC Time 00.249s
Why this strange freq? Pretty high for measuring this kind of stuff...
Reading may be a bit off.
Anyway lets say its correct - then XL is about 5.5...6.7ohms at your working freq (about 300Hz?).
Not the worst coil in the world. Q about 2.5...3.
But the effects I was talking about take place at much higher Qs - phase angle should be 85'+
Quite problematic to achieve with this small half-toroid.
So in that sense it is not correct replication... unless I'm totally overlooking something.
For example in original video the magnet clearly has very small effect on half-toroid inductance
becuse toroid is huge and magnet is pretty small and far away.
In your case the inductance difference is probably large in 0' vs 90' positions.
I think setup would behave as in Miroslav13 video when there would be:
- large phase shift >85'
- neglible change in half-toroids inductance in 0' vs 90' positions
- lossy core
gotoluc
Quote from: yssuraxu_697 on March 23, 2014, 02:46:21 PM
This is my new LCR meter, it auto adjust Frequency from 1Hz to 500kHz
http://www.ebay.com/itm/390609554261?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
gyulasun
Quote from: gotoluc on March 23, 2014, 02:05:37 PM
Luc
I simply used google translate to reverse-translate your Russian text... and thought you also made a typo with the word "on" instead of writing "no" as in your English text.
Gyula
yssuraxu_697
Quote from: gotoluc on March 23, 2014, 03:10:27 PMThis is my new LCR meter, it auto adjust Frequency from 1Hz to 500kHz
Hm... this instrument should be operated with caution because when you are measuring very far off devices real operating point reading may be quite different.
But probably ok in this case.
