Thanks to ALL for your help!!
The Thomas Motor
Started by k4zep, March 05, 2014, 05:09:12 PM
gyulasun
Hi TinselKoala,
Thanks for the video links on your earlier Orbo (oops Orbette...) builds and tests. I went through on them and also on some earlier posts of yours when the Steorn-craze raged and I believe you must have gained a huge amount of knowledge on such setups.  If you do not mind to share some chips like which is the best core material to use for instance? Is it having the square loop B-H curve or it is not a must?
[Somewhere in one of your pictures I saw 'W' material which has a u=10,000 (here is a link to it if that is indeed the core you used: http://www.mag-inc.com/products/ferrite-cores/w-material ) or you tested other core material types?]
Another question would be, could you recall what efficiency you actually measured, with the methods you have mentioned? Have you attempted to recover the collapsing field energy of the core after the current switch-off and is it included in the efficiency estimations (or that energy is so small that no worth to collect?).
Thanks,  Gyula
P
synchro1
@K4zep,
Really cool project. I wrapped a spiral magnetic haywire coil with magnet wire, so it looked like a wound up spring when finished. I stuck two tube magnets to each end in attraction. When I charged the magnet wire, both magnets released and dropped off. The magnets were attracted both to the magnetic haywire spiral core and each other.
Now imagine two magnet rotors, north poles on one and south poles on the other with the spiral spring coil in between. The rotor magnets on each rotor will be attracted to the magnetic wire core and to each other as well. When they're at TDC, the coil charges, masking both the magnetic material and the attraction between the rotor magnets. One pulse driving both sets of rotors!
Furthermore, a ferrite toroid, standing on end could handle four such rotors, one set for the top and the other two for the bottom with the result that one pulse would drive all four rotors. Both rotor sets attracted to the ferrite, then masked to both the magnetic ferrite and their mutual magnetic attraction by one pulse!
k4zep
Quote from: synchro1 on March 13, 2014, 12:28:26 AM
@K4zep,
Sounds good to me, do you have any pictures to show the basic motor?  Drawings?
Ben
synchro1
@Ben,
No, I just dreamed it up thinking about your project.
k4zep
Well, build it and "they" will come!  What you got to loose
Ben
