Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
EMJunkie
Sorry Guys, I think I have broken the thread! I was trying to explain the Circuit issues.
I hope team OverUnity.com can fix this up for us as soon as possible.
All the Best
  Chris
EMJunkie
Hi All,
Thus far the TL494IN Chip is only good to 300KHz.
Anyone want to check and verify this?
All the Best
  Chris
EMJunkie
Hi All,
I have made some small changes to the Schematic. Revision 1.1 is now current.
All the Best
  Chris
EDIT: Image Removed.
EMJunkie
Hi All,
Apologies, mistake and move around of the Tags.
All the Best
  Chris
EMJunkie
Hi All,
I hope I don't have to re-explain this. Page 69 on this thread appears to be broken still!
Major Circuit Differences
Reference Values used from my schematic
The Charge Cap is C2 (50V 2200uF) with Over flow going into C3 (35V 1000uF) when the Switch is on. Of Course if the switch is on then C1 will also charge!
The Run Cap is C1 (50V 1000uF) This Cap does not get Discharged when either FET's Q1 or Q2 get switched on because of the Diode D4. This Cap is the Cap that keeps the Circuit Running when the Coils get switched and the Capacitor Voltage drops below threshold!
The way the circuit was drawn in the other schematics, all Caps get discharged when either FET get turned on and if the Caps threshold voltage is reached then the entire circuit looses power.
All Caps re-charge from the Diodes after the 19 turn coil. We both know what this means, that there is an off period (Duty Cycle) where all caps must sustain the circuit for a period.
NOTE: The Circuit "схема деда 2.jpg" Translated (Scheme Grandfather 2) which havahung very kindly posted corresponds the closest to the Akuls0083 Lantern No 3 Revision one, with the external switch mode power supply. The circuit is very close to the second revision except for a PNP Transistor missing from one FET.
There may be RC Time Constants involved here also. If the Capacitance is a long way out we will loose the RC Time Constant at the Frequency desired.
Hope this description helps!
All the Best
  Chris
Please Note: TinselKoala did not draw this schematic only added the Values.
