Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
MenofFather
Quote from: havuhung on May 02, 2014, 06:49:38 AM
Hi MenofFather,
You have printed circuits from the circuit diagram, please share. There may not need to adjust anything else? Work done on the core windings ferrte? . .
I not printed circuit. I dont knwoh that exatly need ajust. But maybe and nothing need ajust, only frenquency. Akula say, that gose пачки импульсов, that means impuls, impuls, impuls.... silents and again impuls, impuls, impuls... And if you make generator who sends this pachki of pulses, then not need maybe that ajusting and no need any fedback, then maybe be easear. If about turns, here not wery important how you wound primary and secondary, just wound good like in standar transformer. Air gap also not wery important, you with it also can little maybe ajust.
havuhung
Hi MenofFather,
If I understand correctly, so it is crucial to success, it is true cycles ferrite resonators right? . . I think if only (impuls, impuls, impuls). . like a pulse transformer to increase or decrease the output voltage that! . . did not achieve OU. . .
MenofFather
Quote from: havuhung on May 02, 2014, 07:59:42 AM
Hi MenofFather,
That is resonators? Were maybe be crucial, that is pulse pulse pulse__________pulse pulse pulse___________pulse pulse pulse________ and so on. If only be pulse pulse pulse pulse pulse pulse, without space betwen them, then maybe you newer get overunity with schematic of Akula 30 W. Back pach from C13 makes maybe that spaces, whose gose to pin one of TL494. And back pach of C5 and R5 makes maybe duty cycle of that pulses: make bigger load, it makes longer pulses, make smaller load, it makes shorter pulses. Choke betwen C13 and C11 is not simple filter, it is important thing.
havuhung
Hi MenofFather,
Thank you.          8)
Havuhung
JohnnBlade
Hi Meno,
That is correct, with my device if use a train pulse with no space inbetween my amps go up when adding load. When i use a train pulse with space inbetween and at the right distance my device does not notice it loads connected to it. I have done somany tests to verify this for my self and it does make a big difference.
My pulses are x x . . Or . . x x . .   Without space like x x nothing special happens with my device.
I think it got something to by pulsing on a sub harmonic of the main frequency, and giving it space to breath
Greets JB
Quote from: MenofFather on May 02, 2014, 08:48:23 AM
