Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
MenofFather
Quote from: havuhung on May 04, 2014, 06:18:01 AM
Hi MenofFather,
I'm assembling this circuit testing, because considering Video clip shows it is not fake. But the value of the components on the circuit diagram can not certainly true. Regarding the operating frequency of the circuit can approximate as you say, I listened as, Mr Akula axis adjustment potentiometer have similar noise of the oscillation frequency of the horizontal Television. You may provide additional information about this circuit?. . Or more details on Mr Akula said. . .
I not enought understand question about television, about that exactly circuit?
But all schematic that I see on overunity and other forum of 1 W latern is not corect, because that generators not have sinchronisation. How made that sinchronisation I do not knwoh, maybe help skiled electronics in this situation.
Akula say in conference about this divice. [size=78%]http://realstrannik.ru/media/kunena/attachments/3683/partinet2005.png[/size] Frenquency of spark gap he recomendate about 300-500 herc.
And say that this schematic work http://realstrannik.ru/media/kunena/attachments/3683/1_2013-10-25.JPG but not wery succesefully, he with labaratory run it 3 times with selfrunning about 3 hours every time, but he not make corect ajustions and this divice before ajustment all burn or something not good to it makes.
And he speak about generator of Hendershot, that it use not comon material. And  he replicate with labaratory Hendershot divice.
In big divices akula make automatic resonance ajustment.
And first his divice were he mentioning about choke and Hendershot in video, How I understand have hand made capasitor. He recomendate for thats divice, something like this, made hand made capasitors.
Jeg
Quote from: Farmhand on May 03, 2014, 12:11:12 AM
the resonant frequency should be at about 250 kHz
Around the calculated 250KHz, did you notice a peak in amplitude even less than the one at 1.04MHz?
havuhung
Quote from: MenofFather on May 04, 2014, 07:04:49 AM
Hi MenofFather,
I'm sorry for not writing the full meaning of the saying: . . .( Play Video clip, I listened, Mr Akula have similar noise axis potentiometer adjustment of the oscillation frequency of the horizontal Television). . .
So how to sync frequency of the circuit board Akula0083 No3-Disassembly-Lantern, the circuit board has two TL 494 it is two distinct sources of oscillations?
MenofFather
Add information about 30 W divice.
Вопрос: По поводу 30 ваттного фонарика, там ты регулируешь частоты низкочастотного генератора?
Akula say: Нет, ребята, там ВЧ импульсы, пачки ВЧ импульсов, они... ну как вам объяснить? надо включить, дело в том, что когда у вас трансформатор при включении входит в низкочастотную амплитуду, у вас там уже автоматически будут формироваться пачки импульсов, то есть, потому что там идёт обратная связь по току, то есть, когда уже светодиоды перенакалились подают сигнал ТЛ генератору, ТЛ генератор выключается, соответственно происходит перенапряжение, там идёт двоичное уменьшение скважности, то есть выключение полностью. Тем более, если вы даташит расмотрите, у меня там на самой схеме отключено плавное регулирование скважности генератора, он либо есть, либо нету, поэтому там формируются пачки импульсов с частотой ферорезонанса. И он автоматически формируется, так как у нас, допустим, конденсатор зарядился до необходимого напряжения, то есть прошла определённая пачка импульсов, ТЛ генератор, он выключил в это время транзистор до тех пор пока конденсатор не зарядиться. Этот цикл формируется низкочастотной амплитуды общего трансформатора, который уже в этот момент входит в резонанс.
Арунас: Ну вообще на счёт этого, на овеюунити форуме долго мучались, пытались понять, как эта обратная связь работает.
Акула: Ну там видишь, какая ерунда получается, ТЛ-ку ставишь вне плавное регулирование скважности, да? по обратной связи, а резкое выключение, либо есть, либо нет сигнала и получается так, ТK-ка дозарядила, видит дозаряженный конденсатор, она выключается и это будет происходить циклично. Так как в током трансформаторе уже образовалось амплитуда и она этот цикл начинает автоматически связывать, то есть, тут ТЛ-ка, она по сути дела, она не является, как таковым генератором. Она уже делает всё, что происходит в самом трансформаторе. То есть уже трансформатор начинает рвать цикл включения пачек импульсов и выключения на ТЛ-ке, подавая этим самым ток на светодиоды, отрубая по обратной связи, да? то есть по комаратору, эээ вторично уже дозаряжая конденсатор. То есть давая сигнал на выключение. То есть ТЛ-ка там зависима, она как таковая не формирует ничего, в ней задаётся именно скважность, это - равная феромагнитному резонансу и частота следования импульсов, а цикличность их уже формируется самим трансформатором.
Арунас: там насчёт, следующие два момента. один у тебя (не расслышеное слово) как частота, а второй это принцип, где ты находишь именно для обратной связи насколько я понял, да?
Акула: Да, то есть смотри, по току, когда у нас светодиоды начинают больше тока пропускать, у нас идёт команда на выключение полностью ТЛ-ки.  То же самое, идёт перестраховка по напряжению.
Арунас: Ну я так и понял, спасибо.
Акула: Теперь смотри: у меня третья ножка задействована. Да? там через 22 нанофарада стоят, это для чего сделано? Капратар и пятнадцатый компаратор непосредственно силён (может не такое слово) по напряжению именно со разделителем по первому и второму ключу, вот, это что делает? Это блокирует скважность, там нету плавной регулировки скважности, она там либо есть, либо... Поэтому у нас там ТЛ-ка, надо понимать, она работает пачками.
Вопрос: Роман, скажи, конденсатор, накопительный C3 2000 микрофарад, можно его больше ставить по объёму?
Акула: В принципе вот этим конденсатором и формируется та основная переодичность включения, отключения ТЛ-ки. Ну а вторичная, это ток, да? то есть это напряжение на светодиодах. То есть меняя этот конденсатор вы будете менять цикл включения и выключения ТЛ-ки, так как она будет смотреть контроль заряда на рабочем конденсаторе. ... Когда вы включите такую систему, вы увидите с выхода ТЛ-ки, что? что там идут пачки, вот, конкретно длительность их вы отстроите по частоте ферорезонанса. Следование их вы уже будете смотреть на мощность, да? затраты к выходу, то есть количество в пачке сигналов. И вы видите цикличность, что на самом деле, она циклична, она практически 50 на 50 получается, работает-выключилось, работает-выключилось, это как раз и есть управление конденсатора рабочего. ТЛ-ка видит, что конденсатор дозарядился, она выключила, нет сигналов. Пришёл уровень заряда, она включается и вот это начинается циклично идти. А эти циклы, автоматически должны совпасть с низкой частотой уже в трансформаторе сформированной и они начинается... в автоконтроле всё таком получается. То есть, это надо делать, чтобы понять.
That from one conference.
Длительность менять С3 конденсатором. Change how many pulses gose from TL494 need ajust with C3 capasitor for diferent cores.
MenofFather
Quote from: havuhung on May 04, 2014, 09:06:32 AM
So how to sync frequency of the circuit board Akula0083 No3-Disassembly-Lantern, the circuit board has two TL 474 it is two distinct sources of oscillations?
I do not know how sync. But then opens one generator, must at same time opens and other generator, only one generator frenquency low, other hight. Only close can in not same time if I good remember.
Maybe verpies or TK try draw schematic how sync two generators. Because I try with not synchronised generators [size=78%]https://www.youtube.com/watch?v=-6nbYdYpIZc[/size] and hight frenquency generator not baisicly made any influence to low frenquency generator and power consumption with any frenquency (200-500 kiloherc) and any duty cycle (10-45 precents).
