Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
alejandroguille
Definitely Akula works for the government.
Neo-X
I figured out the secret of one of the akula device. Akula replicated 3 type of overunity device, the first is teslacoil or ground type, the second is tpu or nmr type and the third is smartpak zpod or core type ou device. What i fully understand is the core type. It is possible to extract energy in inductor by converting surrounding heat energy into electricity. Although it is possible to use 1 coil to do it, it is more easy if two coils. One is occupying only a small portion of the core and the other one is occupying the large area of the core. It is much better if the secondary coil occupy the whole area of the core. By applying pulse to the first coil (magnetization phase) produces greater power to the second coil (demagnetization phase).
wayne49s
Hi,
I was reading the same topic on overunityresearch and T-1000 is trying to close the OU loop. This message is for him if he has run out of ideas. I've been studying the schematic, and I believe that the bottom of L2 (with the diode) needs to be connected to ground instead of the C3+ line. Otherwise I don't see how it can charge the C11 with the BEMF.
Maybe someone with access to that forum can pass the message.
T-1000
Quote from: wayne49s on May 27, 2014, 05:11:00 PM
Hi,
Hi,
I managed to fix circuit and posted it in http://www.overunityresearch.com/index.php?topic=2358.msg38968#msg38968
The BEMF appears on OFF state of MOSFET and is on reversed polarity so the capacitor C3 gets a charge then it goes to LEDs after certain voltage level. If you try connect L2 directly it kills BEMF (I tried to play around with diodes) and raises input amperage consumption.
Cheers!
Google
Akula is a fake like all other OU claims.  >:( >:( >:(
Dont waste your time and hopes guys.
Move on.
