Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
sm0ky2
@Graham
The 'bucking transformer' was one of the original
"Frequency doublers".
This was taught to us in engineering school
in the late 90's, early 2000's
Today we use IC counters and logic circuits because they
do the job more efficiently
The way it works is when you induce a signal across the two coils
The EMF collides about in the center of the empty part of the
inductor, there at the bottom where there is no coil.
Then goes back in the other direction.
If you used a single pulse you would see the feedback signal
return through the primary.
With constant input signal like you have, what you see is
That tiny ripple appear in spots along the input waveform.
Adding impedances in certain places can bring the return
signal into phase with the primary, so those ripples line up
with the peaks and troughs of the original signal.
ourbobby
Quote from: EMJunkie on April 24, 2014, 12:01:01 AM
Thanks Nico8k! I believe we can do it. If we all work together!
Welcome to the thread!
I have a friend that has worked on the E Stress... Its concepts in my opinion has merit. My friend was not able to get the E Stress working as it was laid out. There could be something missing that could be the key. I did have a look at it, but was working on other things at the time so could not concentrate too much on it.
Good Luck I hope you get it!
All the Best
  Chris
P.S. I am sorry if I miss anyone's post's. I nearly missed this one, so sorry, I don't mean to be rude. E-Mail me or PM me if you want?
P.P.S: I don't use energeticforum anymore since before the Aaron Murakami Scandal.
Hi EMJunkie,
                   Better late than never with my reply!
I have myself only recently come across the E_Stress Generator. I am curious as to your friend's findings and technique. Looking at the description of the E-Stress generator, it would appear to work. As output is concerned, this might be a matter of either size of the unit or level of pulsing voltage. The key to this operation has features reminisent of Don Smith's approach; that is, high frequency pulses of high voltage and capture of the "E field". Of course, to get Don smith's circuits to work, one has to pay a bit of attention to "Tuning" the apparatus. This I think is the case here. The E-stress unit has to operate as a sort of cavity resonant container. It is, to my mind, a quite elegant use of known techniques in a disciplined and economical design.
I am trying to find time to build one!
Thanks
ourbobby
B.Brave
Quote from: Grumage on March 24, 2014, 05:56:26 PM
Dear All.
I have just finished chatting with T-1000. He passed on this fairly simplified control circuit which might help those, like me, who have a bit less electronic skills.
I am also providing an eBay link for 1 W LED's that will be just right for a starting load.
http://www.ebay.co.uk/itm/10-1W-High-Power-Pure-White-LED-Bright-Light-Lamp-Bulb-Bead-DIY-/251088281787?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3a760720bb
Keep on trucking !!  :)
Cheers Grum.
Hi All
Did anybody make 30W generator by 555 timer? Help.
I am just finished my scheme and trying to find proper signal and resonance frequency etc. But lost the way...
