Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Grumage
Dear All.
I can confirm your suspicions as regards the transistor getting hot. It get's REALLY hot!!
I have spent the greater part of this evening trying various frequencies and m/s ratios whilst dumping the output through a super fast FWBR. In fact I got better results connected the other way round !!This was accidental on my part but the results were definitely interesting. Even with a step down ratio the scope was seeing 50 V pulses and a ringdown. Holding the circuit run for up to a couple of seconds.
May I courteously suggest that you guys should make the transformer and try driving with a PWM device as per T-1000's earlier post. A few more stabs with different coil configurations might just see a breakthrough??!!
Cheers Grum.
4Tesla
I found this one FDP030N06 rated at 193A.. are there any rated higher?
4Tesla
I think this is the max.. not sure.  FDP025N06 265A !!
Farmhand
Quote from: verpies on March 10, 2014, 06:36:56 PM
The author of this video says that he does not know how, but his device powers a 200W LED flood light (to unknown brightness)  without any hidden batteries and hidden wires.
To analyze it properly, I need scopeshots of simultaneous current and voltage waveforms on both windings of the transformer/choke.
Come on guys I could fake that video easy ! This guy doesn't show the back of the wooden board, and the transformer seems to be attached to the board, it doesn't seem to move to me. he should be able to move it a couple of inches but he doesn't, he doesn't move the circuit board either.
Video.
http://www.youtube.com/watch?v=OOG6YQ_6K6k
What are the chances he has a third winding on the transformer and the ends of that winding go through the wooden board to a high frequency inverter or pulsing circuit to power the transformer, then the circuit blocks the transformer output from going directly to the light until the circuit is energized to effect switching there so then the transformer  powers the circuit by being itself powered by another supply.
Or some wires could be connected to the back of the circuit board simply with another battery providing the 12 volts or whatever he wants for the power circuit (which in turn supplies the switching circuit once the switching is started by the visible battery).
Or he could have 3 x 12 volt batteries directly powering the LED after the circuit starts. Easy to fake.
Cheers
P.S. I really see no point, but I could set up a 200 Watt fake to the standard he shows, If people keep referring to the video I probably will.
Dave45
Quote from: Farmhand on March 11, 2014, 08:35:57 PM
Video.
Cheers
Trollin trollin where's your troll buddy's
I have a novel idea maybe try and make it work, wow who would of ever thought.
