Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 40 Guests are viewing this topic.
Google
Quote from: From other Planet on March 12, 2014, 08:48:08 PM
uhm that famous Don Smith expanding can be seen very easily: Just charge capacitor with hv transformer + diode(s) and discharge cap through spark gap to ur DS primary or whatever. If u now place scope probe close to diode or cap or leads u will see the expanding waveform(trumpet form), i have done it many times. Sadly it alone is not OU. Its just the cap being charged and thus maximum voltage rising... after spark discharge a new trumpet develops...
There may be other scenarios of course where u see trumpet wave and it IS an indicator of OU
Successful resonant magnetic coupling might be the key to overunity. But not easy to achieve. Just my 2 cents.
Best,
lost_bro
Hello From other Planet
Yes, you are correct.....
And a SG will generate a VERY broad spectrum of frequency range as a driving signal.   Contained within that  wide frequency range that your SG generates with each spark, there will be the principle frequency or at least harmonics of the principle frequency that your Tesla coil or DS coil is tuned to:
So in essence a SG is a Hit and Miss proposition at best, being of a wide frequency band you will inadvertently hit your mark.  The SG is NOT tuned to the rest of the system,  of course the Primary and Secondary of such a system should be tune to resonate at the SAME frequency.
Edit;  yes, Telsa did use a rotary SG and HG-SG to modulate frequency of his Spark , and even still the SG is a dirty signal at best...
Now design a SS circuit with precise frequency control, which operates at a very narrow frequency range (ie: 1x10e-6 Hz) and try again to generate the Trumpet waveform......
You must have  the inductive and capacitive reactance of your tuned system canceling at the precise frequency ( or maybe harmonics of ) of your driving circuit which power the gate of your driving MOSFET (s).
This TPU circuit does not utilize a wide frequency SG, it is using single frequency which must hit the mark precisely or it will NOT ring properly.
And yes, the trumpet waveform in and of itself does NOT signify OU......  but we must start somewhere.  I personally believe that it is how you use this trumpet waveform that can catalyze OU.
Please see attached pic of Waveform of Charging and Discharging of Capacitor, usually requires 4TC to reach apogee of charge, this is NOT the Don Smith wave form I am discussing.
On the other hand the Trumpet voltage waveform indicates voltage amplitude which increases with time,  this is an indicator of a system tuned to resonance.  A very different scenario from the posted below standard Charge and Discharge pic. of a capacitor which is NOT part of a system in resonance.
Take care, peace
lost_bro
dllabarre
Quote from: Google on March 12, 2014, 09:04:13 PM
Thats exactly what I said, she never showed her work to anyone, deleted all her posts and vanished from the forum. When will someone do that ? A faceless internet character doesnt do that until they have a working device and want to hide something.
Best,
Except Zilano NEVER build anything.
All she did was copy & paste other peoples work.
Show me one pic of a device that SHE built.
You can't because she didn't build anything.
Every time I and others challenged her she would delete her posts and move to a different thread to start again.
She was also on other forums like energeticforum.
She scammed you guys.
Google
I am wondering why would anyone behave like she did.  :-\ :-\ :-\
I read somewhere she has a 10kw device powering her home. If all is untrue, why she wasted hers and others time and effort on the forums.
I hate the sucker b!t€h.
Best,
Google
Consider for a moment how long worldly triumphs last. They are but the play of the scintillating name and form of the Divine, which is the core of every being. Earn the vision that sees the Divine inherent in all. We are not troubled when something is good; only when something is bad. This is because the goodness in us is natural. In our evil aberration, we are worried and alarmed when we slide into wrong or pain or sorrow. This is because nature plans us to be right, to be happy and ever in a state of joy. It is a pity that man has lost his understanding of this basic Truth.
