Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Hoppy
Quote from: energia9 on March 16, 2014, 07:57:17 AM
just try doing what you have just said with this floodlight,  buy one and do it. :)
OK, I take it then from your comment, that its not practically possible. In which case, he is probably driving the in-built step-down converter from his inverter, probably powered from a hidden battery under the circuit board.
energia9
Quote from: Hoppy on March 16, 2014, 08:04:16 AM
there is a lot of ways he could have lit that light to ''full brightness'' , especially with his zoomed bamboozle camera movements
MenofFather
Let say if that not fake. Then after back EMF is self oscilations, I see in oscilioscope, in my transformer about 250 kiloherc. Maybe need tune to this frencuency? Or maybe this oscilations feed capasitors? So maybe need duty cycle use about 30 precent, to get longer, more this oscilations? Akula write, that this is transgenerator Melnichenko. Melnichenko use duty cycle about 30 precents. But in this wersion, I bealive, that air gap is not needed!
MenofFather
So author officialy answer, that 2000 uF capasitors are 35 volts.
He also wrote "Повторяю ещё раз ! Только светодиоды и ничего другого там больше не работает. У меня не получилось запитать лампочку. Соберите сперва на диодах, а там эксперементируйте."[/font][/size]
"Say one more time! Only light emiting diodes and nothing more here not work. I not get sucsesfully feed small lamp. Asamble first on diodes, and then eksperimentate."
Dave45
You guy's crack me up, instead of trying to understand the principle of whats happening in the circuit you sit around trying to figure out how they faked it..........why are you even here? ??? ?   go play ping pong or watch tv like the rest of the sleepers.
Romero said there's no power regulation on the bottom side of the circuit and C2 C3 and C4 could blow if the load does not match the power output, so be careful.
