Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 25 Guests are viewing this topic.
T-1000
Quote from: lost_bro on April 07, 2014, 09:28:04 PM
Hi  All;
Sorry if this is OFF topic:
Here it is , the QEG user manual....
take care, peace
lost_bro
Hi, thanks for the pdf, I already did check out on it and my first impression was - well, it might work with proper adjustment.
From the knowledge I have, when you make toroidal generator there was at least one case I know already when it ignored shorted circuit and did not slow down motor. Also there is coil shorting involved and that is where Ismael Aviso car is based on. And on resonance the consumption is minimal with maximum output...
So all this stuff makes sense and needs for someone to pick up and try to assemble small to medium size unit then try to get maximum performance out of it ;)
Cheers!
Quote from: Hoppy on April 08, 2014, 05:46:13 AM
There is a massive DC coupling which is why I deliberately AC coupled the waveform to see it clearly, which is why the menu strip is in the shot to clearly show that the signal is AC coupled. Look at the vertical scaling!
Yes, the mosfet is getting very hot partly because of insufficient gate voltage, as I was not able to raise the supply voltage above 6.8V without an excessive current draw of around 12 Amps! This circuit as it stands is performing well as a mini hand warmer.  ;D
OK, if you are using AC coupling deliberately that's fine... but then of course your "spike" isn't really going negative at all, is it, since it's sitting on top of your "massive DC coupling" or rather component, and the reference baseline of your channel does not represent "zero voltage" or ground level at all, but rather the value of the DC component.  It would be nice to know the value of this massive DC component, don't you think?
You are also using 20 mV /division which is the most sensitive setting on many scopes, so your amplitudes aren't that great compared to the DC component.
The channel's AC or DC coupling is continuously displayed on your scope, by the presence or absence of the little sine wave symbol next to the channel setting, below the trace display area.
Thestone
Quote from: T-1000 on April 08, 2014, 07:56:36 AM
Cheers!
I think the mix in in the putting... if they have so many years working on this where is a working prototype... with a HD clear video not what you find in the web, all blurred out and no measurements of input and output....
I think these people are very good in creating a marketing campaign and promise utopia for energy and offer it for free to the word but of course then they ask for donations... you see so many donations websites about this HOPE girl it is ridiculous... she most be making millions !!!! and of course she does not has anything working that she can show for....
Give hope of something to people and they will follow you... that is way the mix it with religion...
The Stone.
dllabarre
Where is this video of one "working?" The last I heard they were having it rewound because it _didn't_ work but rather shorted some windings.
OK, it has no magnets, but it has the functional equivalent, in the changing flux path provided by the rotating armature. Since one set of coils is energized by the mains, it is making a field, which is then channeled across the halves of the torus by the rotating bar. I have no doubt that high voltages can be produced in this manner, just like a magneto does.
Running itself, though? Nope, that it will never do.
