Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
magpwr
Quote from: verpies on April 12, 2014, 07:59:41 PM
Is this what you had in mind?
hi verpies,
I have just edited circuit diagram as attached which i didn't spot earlier.
I hold no secrets there are only 2 possibilities related to the connection from the pot core at the left side as side which the copper wire from pot core can be easily swapped on circuit board.
The circuit diagram attached is one of the possibilities.
The other possible way is we just need to swap copper wire as shown in my drawing.
If you take a look at the attached top side photo.It also looks like transistor collector to ferrite pot core then to pin1 before diode base on 2nd possible connection.
I have also attached my edited drawing on where the copper wire needs to be swapped base on 2nd possibilities.
This is just my personnel opinion only base on the attached circuit diagram the value of R3  100 ohm resistor leading to the green led should be replaced with a higher value anywhere around 560 ohms.
Since i don't want to steal too much "signal power" meant for the base of the transistor and maintain a dimly lit green light which merely serve as indicator purpose only.
Some experimenting is required to find out which is a suitable NPN transistor for the job which shouldn't be a big problem at all.
This is the latest update minutes after posting.I have attached mini video to show my existing IC HCF4069UBE blinking happily on Li-ion battery 3.4volts which i am using 330 ohms to led.
The capacitor value for 4069 in your circuit diagram needs to be lowered from 10uf to 4.7uf to get the green led blink rate quite similar to the youtube video.
I'm guessing the resistor to drive transistor may or may not need to be lowered from 100 ohms but not confirmed at this moment since i'm waiting for component MC34063 to arrive. ;)
The current drawn at this testing stage with green led is around <1mA
For everyone else,
This experiment is only suitable for those with oscilloscope to view 2 signals generated by 2 IC else it would be a failure if signal is not in sync.
I don't make promises if this circuit will work as intended since this circuit isn't mine. :D
MenofFather
Quote from: 4Tesla on April 12, 2014, 05:19:37 PM
@magpwr
Nice work!   8) You should start a new thread for this project.  I will follow.
This divice based on not akula 30 W divice... Author on this divice before several months also try replicate this divice but unsucsesfuly and now he make it with small output.
It based on this schematic and divice http://eurosamodelki.ru/uploads/images/83c140d3ddb49e354c61634b21931c92
http://eurosamodelki.ru/katalog-samodelok/alternativnaja-energetika/generator-energii-na-nelineinoi-induktivnosti
Aouthors is two defferent guys.
Princip can be like that of this divice http://realstrannik.ru/media/kunena/attachments/1766/uzel.jpg Транзисторы закрываються и открываються поочерёдно.
verpies
OK, I altered the values of R3 and C4 according to your recommendations.
I kept the connection to R0 (the CSR made out of the wire jumper).  If you look at the circuit diagram on page 5 of this datasheet, you will see that it makes sense.
MenofFather
doktorsvet
Hello ladies and gentlemen, scheme flashlight vadim guk published on the website zaryad.com
http://zaryad.com/forum/viewtopic.php?f=8&t=8534
