Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 139 Guests are viewing this topic.
magpwr
Quote from: MenofFather on April 13, 2014, 05:14:57 AM
Here my one schreen shot.
hi Menofather,
I am using the  circuit diagram posted by verpies.
I have already tested 4069 led blinking and it's working.I have attached led blinking video once more.I am just waiting for MC34063 and around 4cm ferrite pot to arrive.
Kindly do wait for 3 weeks once parts arrive only then i can report result.
In the meantime i will just wait for any feedback if anyone got all the component available and circuit assembled.
I'm aware this isn't the right thread which i would like to end it with a working device and no further question asked once all the details are provided. :D
I doubt i will go for any other free energy "Led circuit diagram" which is not tested.
My method is reverse engineering via youtube video with no circuit diagram provided by the creator of the working device.
In the meantime I have increase the output secondary of Don smith device to around 140volts.
I am waiting for small value capacitors around 10nf to arrive so that i can do fine tweaking at secondary capacitor.
Since my don smith secondary was wired wrongly i merely criss-cross one of the secondary output.
Need to find time to build driver stage for "1200volt IGBT" which i have received then use my 220volts inverter and rectify to around 400volts with around 300uf 400volt cap to switch primary coil.
semenihin-77
К этой схеме Акула не имеет никакого отношения.
В первом видео показан принцип. Частота коллебаний там ниже чем задающий в 34063. Десятки герц против десятков килогерц.
Резонанс ловиться изменением напряжения- резистором.
This scheme Shark irrelevant.
The first video shows the principle. Oscillation frequency are lower than set in 34063. Dozens hertz against tens of kilohertz.
Resonance caught changing the voltage-resistor.
MenofFather
semenihin-77
не работает на других транзисторах, оригинальный выковырял из компьютерного вентилятора.
T-1000
Quote from: semenihin-77 on April 13, 2014, 08:21:18 AM
"does not work on other transistors, took original one from computer fan"
Do you have it self running..? :)
