Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 123 Guests are viewing this topic.
magpwr
Quote from: avalon on April 14, 2014, 03:07:44 PM
It won't work.
Incidentally, there is a list of known fakes here:
http://www.freenergy.com.ua/topic/141-cpisok-avtorov-ustroistv-kotorye-nikto-ne-smog-p/
It includes the circuit you are trying to replicate.
BTW, according to this: realstrannik.ru/forum/temy-atom/134569-qgenerator-na-nelinejnoj-induktivnostiq-rekonstrukcziya-sxemy-i-pechatnoj-platy.html#162073
the blinking LEDs circuit has been confirmed a fake as well. The trick was simple.  One of the capacitors is, in fact, an EDLC device (Electric double-layer capacitor). Once you jump-start the circuit it will work for several minutes.
I am going to make one as a practical joke. I'll post a video of the 'working device' as soon as I can.
~A
hi avalon,
Whose legs are you are trying to pull. :D :D :D
Remember i reverse engineer from youtube video and not base on any circuit diagram provided by anyone.
The capacitors value as found on capacitor is 1000uf 10v and 470uf 16volt. :D :D :D
I would have known first hand if it's fake before i even start reverse engineering directly from youtube video. :D :D :D
Let follow the newly created topic.I admit it was a nice try from you to distract others without any validation made by you first hand. :D
MenofFather
Quote from: T-1000 on April 14, 2014, 05:10:15 PM
Labas :)
Delamorto did have black USSR hard ferrite which also remains magnetized after coils are off. After some discussion with him the core may appear to be made from same material as old Russian TV yoke (that's hint where to look for transformer).
My advice, you might first try to replicate 1:1 transformer first before going wild with all different designs. ;)
I not have that core. I bealive that core here is not important. Because Delamorto first also can not make this divici selfrunning with correct core. Это как говориться, генератор на  нелинейной индуктивности ,тут нелинейная индуктивность смысл делает ,а не сердечник, так упрощённо говоря. :)
verpies
Quote from: elementSix on April 13, 2014, 09:05:09 PM
Hey Verpies, am I reading this circuit right, you know I suck at circuits..  Is this area for output to Primary, and also what do you think of it?
I think it's a coil of a relay.
T-1000
Hi guys :)
Akula showed more details as per my request - https://www.youtube.com/watch?v=_DkjdsQ9vug
In first part he showed effect what happens when Tesla coil effect is applied perpendicularly to normal windings on 90 degrees. Obviously this big toroid was not good success for first intended OU device. The ground wire is used there as well.
In second part of video the circuit board is from LEDs 1W schematics using toroid from 1st part. This is where it was OK on self running it seems...
Quote from: MenofFather on April 15, 2014, 02:51:37 AM
I disagree, the core materials used are most important if we are talking about NMR effect there. Otherwise what makes additional source of energy there for self run and powering small load?
Cheers!
verpies
Quote from: T-1000 on April 16, 2014, 07:26:38 AM
Exactly
