Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
T-1000
Quote from: NickZ on April 19, 2014, 12:21:23 PM
  Not easy, but I'm not giving up. My set up is working well with solar panels/12v, LAB, although I don't have enough panels, yet.  Any help and advice is always welcome.  Thanks Dave.
Good :)
Here are some thoughts about 2 Mazilli drivers:
You can try to make transformer with two primaries and one secondary. Then connect load to the secondary and run one primary of transformer's resonant frequency then the second primary in 1/4 of that frequency in opposite direction on second primary. Then observe clashing frequencies on secondary coil which should cover both primaries then reach second half of gapped core to the middle of second half(GeoFusion way for flyback+choke effect). Maybe you can find a ferrite core which will give response on clashing frequencies (and resulting standing wave which will turn magnetic domains 90 degrees to Z axis). And while doing that you will have Lenz-less induction on secondary... ;)
The resonant part should be running on minimal power consumption before connecting second primary and after this it should not increase power consumption too much.
EMJunkie
Quote from: verpies on April 18, 2014, 09:16:35 PM
More detailed analysis about construction of the transformer gutted in this video can be read in this thread.
Thanks Verpies,
Have read and mulled over the info.
The first post is very good: #msg397848 Nice work from 4Tesla.
One very good diagram here: #msg398173 This is of course Verpies post.
Also looks like the Circuit here: #msg398455
Some good work there Verpies and 4Tesla!
NOTE: To be honest, this configuration does not comply with all other known configurations. EG: 5 output terminals, one copper shield and other things. Akula's Diagram is also quite different from this configuration. Its un-usual to say the least. See here for more information on what I mean: Power Generator in the Nonlinear Inductance
If this work is based on Andrey Melnichenko as some said earlier on in the Russian Forums, then the original schematics, 2 or 3 Coil with one Copper Shield is what one would expect to see.
Cheers
  Chris
P.S: Happy Easter all!
NickZ
   T-1000:  I've answered you on the Dally thread, please check it.
   I will continue discussion of any different types of circuits on the Dally thread. Before I'm asked to leave this thread, as well.  As it looks like there are several people working hard to achieve the 30watt Akula crt. My hats off to those guys...
John.K1
NickZ
First: I do not think it is out of this topic but I am not gonna argue with you.
Second :  I build many interesting stuff and lighting halogen bulb 220V 120w from 24V @ 0.5A at its 40% of its brightness from ONE single coil. So your design doesn't impress me.
Third: I am busy by building SM's TPU's and that's what I do focus on right now.
Happy Ester to all.
I am outa here.
