Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 65 Guests are viewing this topic.
verpies
Quote from: John.K1 on April 23, 2014, 07:16:03 AM
But what is it good for if you have to feed it with new bars after some hours of work?
Do you realize how much energy is released in transmutation of 1kg of Fe or Co?
Don't you remember Acula's first torche was like TPU - it means air core.
It doesn't mean that the device is all air, e.g. the device contains a lot of copper in the form of copper wire and foil.
Do you realize how much energy is released in transmutation of 1kg of Cu ?
Don't you remember whether he got the copper device to work well ?
Calculate the J/kg of transmutation yield before you start discouraging people with your ignorance.
mscoffman
Quote from: a.king21 on April 22, 2014, 08:31:36 PM
The principle of operation of the Akula device is a new type of LENR.
Unlike the Rossi system (which produces heat which is turned into electricity)
Akula produces electricity directly by consuming the ferrite core.
Not consuming the core...First consuming the core binder or wire insulation, a hydrocarbon byproduct I suspect.
"LENR occurs when mechanical phonons are impinged upon a hydrogen bearing liquid in contact with the metal matrix."
>There are interesting twists I've learnt from this recording:
> 4. Lifetime of his devices is limited due to some kind of deterioration of ferrite cores. (They also heating up when units are operational).
In a final operating device I would insist on a designer replacing all large value electrolytic capacitors with tantalum polarized capacitors.
Read the history of electrolytic capacitors, to find out why...they are only approximations of capacitors.
:S:MarkSCoffman
Quote from: EMJunkie on April 23, 2014, 07:37:53 AM
Hey TinselKoala,
My opinion stays un changed unfortunately, I can see it, I can feel it, my senses are not fibbing. Weather Div B = 0 or Div B != 0.
Sorry TinselKoala, I am firm on my findings on this one.
All the Best
  Chris
You don't know how happy that makes me.
By the way, what happens when you cut a bar magnet in half right at the Bloch Wall? Never mind, I already know the answer.
Time for another cup of coffee....
havuhung
Quote from: EMJunkie on April 23, 2014, 05:45:54 AM
Hi All,
The above information I posted may be an entirely different circuit! On further investigation, I believe they, both IC Chips are TL494ln but I cant be certain of this.
All the best
  Chris
Hi EMJunkie,
You are correct, the screen capture image from video shows both the TL494 Chip.
avalon
Quote from: verpies on April 23, 2014, 09:44:44 AM
Use of the term 'transmutation' is, IMHO, incorrect.
I have read posts suggesting that Roman's unit is a sort of variation of LENR. It is not.
I can write a very long post explaining why not, but I am sure that you can find a better article on LENR than  I could ever write.
Have a look at this Mitsubishi pattern:
http://www.google.com/patents/EP1202290B1?cl=en&dq=Nuclide+transmutation+device+and+nuclide+transmutation+method+EP+1202290+B1&hl=en&sa=X&ei=vnQNU-KoEeHl2AXdpICICQ&ved=0CDUQ6AEwAA
or just read a WiKi article and I am sure you'd agree with me.
~A
