Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Nico8k
Hi @EMJunkie and All
I like your contributions, they are very constructive!
When I saw the last translation video of Wesley I realise that the core/transformer that Akula disassemble is very similar to the core in The E-Stress Power Generation System project.
Since I saw it, I have been searching on the web/overunity/energeticforum for anybody working on it but can't find anything.
I have very little knowledge on electronics, I work with computers.
The project is very well explained so please take a look, I know you can understand it.
Look for The E-Stress Power Generation System at the bottom of chapter 3 in www.free-energy-info.tuks.nl
http://www.free-energy-info.tuks.nl/Chapt3.html
Thanks and good luck!
Nico
verpies
Quote from: avalon on April 23, 2014, 01:14:30 PM
Use of the term 'transmutation' is, IMHO, incorrect.
I have read posts suggesting that Roman's unit is a sort of variation of LENR.
...and that "NR" in LENR is what kind of nuclear reaction: Alpha decay, ±Beta decay, EC, IC, Fission, Fusion, ...what ?
It is not.
I can write a very long post explaining why not, but I am sure that you can find a better article on LENR than  I could ever write.
I already am well educated on the subject of LENR.  A search for Low Energy Nuclear Reactions in solid matter induced by EM pulsing techniques leads to this patent - a perfect match.
Anyway, why should I discuss LENR with you if you propose a different operational principle that you want to keep to yourself?
P.S.
I partially wrote that Wikipedia article.
Ed morbus
AlienGrey
Hi all, on one of his video's i can see 494 on both chips, has any one managed to work out the circuit yet ?
Reading this thread recalled his experience of two years ago :
Two generators (70 -100kHz), with access to the key is two different windings of one transformer . The frequency difference is chosen approximately 50-100 Hz. With the output winding which has Mezhuyev primary turns ratio of 7:1 and the output is supplied to a low pass filter with a frequency bandwidth of about 0 - 500Hz.
When selecting a specific frequency load ( wire resistors ) had no effect on the current consumption and resonance processes in the transformer. Moreover, the output included even an ordinary diode bridge ( from LF diodes ) it worked perfectly .
Maybe that's the secret data flashlights.
EMJunkie
Quote from: TinselKoala on April 23, 2014, 12:54:31 PM
You don't know how happy that makes me.
By the way, what happens when you cut a bar magnet in half right at the Bloch Wall? Never mind, I already know the answer.
Time for another cup of coffee....
Hey TinselKoala,
Yes, I also know the answer. One could say the Bloch Wall is a result of the geometry/size of the Magnetic Field. Of course it is a little more complicated than that but the basic idea follows geometry/size.
All the Best
  Chris
