Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
T-1000
I just posted an update in http://www.overunityresearch.com/index.php?topic=2358.msg39158#msg39158
If you will be able to find right ferrite, should be not too hard to try... :)
cosmoLV
Quote from: EMJunkie on May 09, 2014, 01:54:33 AM
Hey Havuhung,
Thanks!
I am convinced (100%) that the ferrite is not the key to success.
Its just a part of the circuit. Look at the success of Avalon over in the 3v OU Flashlight thread. -->See Here<--
5ma @ 2.6 volts = 0.013 mWatts
Akula has many other devices that don't use a Ferrite Core.
All the Best
  Chris
Ferrite has important part of it, but it is only for testing – it is not for day to day use. Ferrite losing it`s domain structure and in the end it stop work.
There is two materials who can capable do the same work as ferrite – thaey are expensive. One is Pemalloy and other MetGlas (Tariel Kapanadze using transformer Permalloy) - the saond what you hear when starting device... (but there are one more thing)
* You need to know - that you do not need to make resonance of coils, but resonance of ferrite or other matereal who can do work (Overtone) in this case.
* Important is how long transistor are opened.
in the end (i think Ferroresonance is not the right word) this is Overtone - resonance in medium, room or in matereal. When you get in overtone, example in sound - you can brick a wine glas. "I talked about this 4 years ago"
Keep your chakras opened :)
NickZ
  CosmoLV:
   You mentioned:
   "We have build 10 Kw device in size of two "bulding bricks"
        end quote.
   So, can you show some pictures, or a video, or a bit more information, like is it self running, etz...
            NickZ
magpwr
Quote from: NickZ on June 04, 2014, 08:11:23 PM
  CosmoLV:
   You mentioned:
        end quote.
            NickZ
hi NickZ,
I agree with you.
It will be good enough for me if there is one photo provided to us which at least reveal a simple proof that "a device was built" since it about the size of 2 bricks.
Taking one photo should be easy.
cosmoLV
Quote from: magpwr on June 05, 2014, 05:20:28 AM
hi NickZ,
I agree with you.
Sorry, no photos no videos. This is just for now! There are lot of to do. (i'm in process all the time)
(the problem why many cannot replicate it is by that you try to do it in classical way. There are two frequencies mixed together, you can make it with any PWM IC or with two 555 timers easelly to check out results, the rest is control of this process by PLL (phase locked loop) or make all on Atmel controller - i do all my experiments with Arduino. (thats all - you even do not need a soldering iron for that)
there are lot of working schematics out there, the hard part of all experimenters and seekers are.. -> (finding out that ferrite resonance) best ferrites are from Russia - old russian flyback ferrites and what i found out there are non russian miniature flyback transformers from LCD backlight transformers - they are small but perfect for tests.
you can even use two transistor simple frequency generator - this is not effiecient, but great for experiments. (in this setup ferrites in resonance exploding after some work time, but here you can exactly can see what is going on) "Remember sound an Wine glas"
all what needed for small  device - divided in blue in pic.
http://s018.radikal.ru/i515/1406/e6/e8c8ebde5c2e.jpg
