Motor Generators - Free Energy - An Explanation
Started by e2matrix, March 10, 2014, 02:06:29 PM
gotoluc
Hi Laurent,
one question, what happens when you add more load (finger) on the one way bearing rotor, does the motor power supply input change?
Merci
Luc
ARMCORTEX
thx you laurent for informing me about this interresting mechanical concept. If those numbers are true from linevich this is major concept
AC motor single phase ? It would be great to see if the motion can sometimes go into a resonance with a specific drive or motion frequency.
DreamThinkBuild
Hi Laurent,
Thanks for the reply.
I built a quick test model with Lego and now can see how weak the oscillation is. At a certain speed it will sit in place and oscillate. I see what you mean also by capturing the imbalance is going to need good bearings or somehow come up with a ratchet system. I don't have any one way bearings so I'll play with it some more see if there is an alternative to taking the power off.
woopy
Yes DTB
Very nice build, to get the feeling of the beast , bravo.
Hi Luc
thank's  for the video.
And for now, i am playing with all i have to disposal to get more feeling on the device.
As i sayd in my previous post , it seems that a very good "one way " bearing is a must. Than i also think that the  transmission mean (the belt )  must be very Unelastic.
And sofar, depending of the  elasticity of the belt and friction lost , or the gear ratio  and rotating speed,  i have so different results that i am not able to   answer your question so easily.
I have to experiment  further, because the Kanarev and Linevitch technicals infos are very small at this point, and as i sayd the translation from russian to english are also very poor.
So as always a hard way
But good luck at all
laurent
