Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
Let's take a look at the "Synchro Scalar Wave Output Coil" first by examining the Bedini Scalar wave detector. Any one following my research can instantly recognize the magnet, coil and LC resonant tuning circuit similarity:
One can see Bedini's Electrogravitational Wave detector is designed to operate inside a Faraday cage.
"The magnet is a receiver for scalar waves, which are detected to "bleed-off" as an oscillation of the magnetic field strength of the magnet. Coupling of this oscillating magnetic field to the coil creates an oscillating current flow into the capacitor This oscillates the voltage input to the preamp, which amplifies and feeds the signal to the oscilloscope for display".
synchro1
Scalar Waves: Bifilar Coil Construction.
You can apparently make scalar waves with a bifilar coil (one wound with a pair of wires instead of a single wire) and pushing opposing currents through the wires (join the far ends together).
synchro1
It's important to keep in mind that MAGNETS ARE THE SCALER WAVE RECEIVER!
"The magnet is a receiver for scalar waves, which are detected to "bleed-off" as an oscillation of the magnetic fieldstrength of the magnet. Coupling of this oscillating magnetic field to the coil creates an oscillating current flow into the capacitor".
Here's a link on JLN's Scaler Wave transmitter. The transmitter tells us something about the longitudinal wave. They are real and have a real effect!
http://jnaudin.free.fr/html/sclxmtr.htm
synchro1
Quote from Bearden about the scaler wave detector:
"The idea is quite simple: install a very powerful bar magnet vertically inside a grounded Faraday cage".
A verical bar magnet facing the Electrogravitational wave would share the same pole orientation as a diametric magnet facing the wave on end.
synchro1
The Chiral Homopolar can generate output through a ring of diametric magnet core LC "Synchro Coils" with no Lenz drag, because the Homopolar fields are stationary, and there's no induction taking place, they're projecting "Gravity Waves". It's possible to drive the Chiral Disks with a diametric tube on an axle efficiently powered by a pulse coil. The 7.83 hz RPM's are slow enough to use a Reed switch with a reverse biased LED loopbak circuit like the one shown by Igor Morz that runs for practically nothing.
A diametric tube could be placed in the middle between four Chiral disks, two on each end, both ringed with spoked "Synchro Coils". This would probably generate Kilowatts of free energy! This pretty much sums up my theories and design. Now we need some builders!
