new magnetic engine proposal
Started by superhero, March 15, 2014, 10:46:42 PM
superhero
Please view my ts9engine.doc attachment above first.  This is a new magnetic engine proposal utilizing a new magnetic shielding material called ts9.  The proposal is very simple a 6 years old can understand it.  Guys please let me know what you think.  I have another proposal also called primer fields.  Looking for partners to build this thing to life.  Any body please help.  Im exhausted ......uhhhhh
anshassi@yahoo.com
Paul-R
Have you seen this:
http://www.free-energy-info.co.uk
Try chapter 1, Ecklin (Brown) and others.
New magnetic shielding material? The video was uploaded nearly three years ago. I have bunions that are newer than that.
I think you will find that bismuth and other diamagnetic materials do indeed interact with magnets nearby; it takes work to put them into the magnetic field, plus, if they are conductive, eddy currents will be induced in the material as you move it into and out of the field of the PMs, and the fields from the eddys will oppose your motion ... this is also a process that takes work away from your "output".
Good luck experimenting; your document is very well put together and well presented. If only the material actually worked as a true shield, instead of a mere partial deflector....
Check out the website mentioned in the video description:
http://www.magnetmotor.at/projekte/MDS-III/MDS_3-de.html
Even the stuff with the flashing "NEW" tag is from the summer of 2011, and this website page says it was last updated in July of 2011. I suppose the inventor is too busy raking in the cash to post updates on the website.
Oh, I see the stuff from 2013 too. Good luck!
gyulasun
Quote from: superhero on March 15, 2014, 10:46:42 PM
anshassi@yahoo.com
Hi Superhero,
There were two more short videos on this new material back then, you may have seen them:
https://www.youtube.com/watch?v=MMWHHtL98YI  and https://www.youtube.com/watch?v=SQw-nk6nYs0
Indeed these materials (TS-5 and TS-9) seem to reduce the original strength of a magnetic field.  However, what TinseKoala mentioned in his above post are valid and further hand-on tests with possessing such materials could reveal further useful info on how useful this material is.  For instance, if you attempt to measure electical resistance between two close points anywhere on its surface area, that would be a useful info.  And using a gauss meter or anything simple B field indicator to check the field strengths at sideways, behind it etc would also give useful info.  Maybe you are already aware of such data.  Also how can you obtain or maybe make (if possible) such material?  Any ingredients needed for such new materials are known by you?
Thanks, Gyula
gyulasun
Hi superhero,
Your texts on the different material properties sound good but it is surely not so simple.  The problem is that so far most of the known  dia or paramagnetic materials have a permeability of  very very near to unity i.e. very close to that of the air i.e. their effect is that of an air gap sized from the dia or paramagnetic material thickness in question.
Please go through this patent application description  here first, you will find mixtures of different known materials with weight percentage and in gramms and some measurements on them, it will probably sound fine to you: http://www.rexresearch.com/wadle/wadle.htm
And then please read this thread here on this forum, first Reply #7 in the link below and then the rest mainly under of it because replication attempt was described too :  http://www.overunity.com/6207/deflecting-magnetic-field-shield/msg143204/#msg143204  (at the end of Reply #7 you will find the granted patent pdf for the above application).
If you wish to tell your opinion later on, please answer here.
Greetings,  Gyula
