Free energy device 70watts by Hans Coler
Started by policiarj2, March 20, 2014, 02:41:43 PM
MarkSnoswell
You can read more about the Coler documents we uncovered here...
The Inventions of Willi von Unruh and Hans Coler.
http://chavascience.com/papers/the-coler-devices
As you can see -- it appears that the invention was Willi von Unruh's and that Coler continued Willi's work.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
MarkE
Quote from: MarkSnoswell on March 22, 2014, 08:00:44 PM
And despite many years of your pal Mark Goldes claiming to have unlocked the supposed secrets, no one at either MPI or the successor Chava Energy has made a Coler device work.  the seventy year old myth remains a myth.
policiarj2
--I think we can understand the Hans Coler device just if we understand what does the ZPE-flux accelerator, in the link that I put before appear a explication:
When two coils are connected symmetrically in opposite directions against each other, this results in a non-inductive coil.
When a current flows through this, it generates a fine Helion 1 field which shields the coil from the space flow ether. In a densely filled space with magnetic lines can not penetrate an external field. It is designated as a shield. The highest resulting field is also called ZPE. Only this is needed. The coils are connected together as a non-inductively, the escape is not annoying, and electromagnetic flux affecting, and the pulse coils affected.
--I dont understand it, when you put two opposite forces always the forces are cancelled, What you can get from it?, resonance? well I could find even other great information:
Excitation
1 The oscillators can be alternately pulse each other at least as two, or multiple group.
2 The oscillators are pulsed by a moving permanent magnet (rotating). (Motor-generator)
The oscillator may only induces short to generate a magnetic field and an output power.
Then the oscillators must contact can oscillate freely to generate an accelerated ZPE flux.
All power generators require excitation by radiation, which is mostly produced by radon doped iron, or by fast-moving permanent magnet.
When the oscillator is energized, increasing the amplitude and the magnets are moved slightly (up to 9mm) to resonance offset, and the best focus ZPE-wave apart. At maximum amplitude of the switch is opened.
If the generator does not start, or runs poorly, a small DC voltage should be switched serially in both circuits. The Spannungeinspeisestelle must be connected in parallel with a capacitor at 330 uF.
Left: A version with only a magnetic bar. The two halves of the winding are drawn only to illustrate the connections of the magnetic core is not of a continuous winding, but rather as a cut. The number of turns must not be too high.
Right: jump start. Pulse supply with a battery a transformer to the non-inductive coil. The diode is poled with the pole changing according to the flow of the connected solenoid, and directs the pulses equal.
More info here:
http://translate.google.com/translate?hl=en&sl=de&tl=en&u=http%3A%2F%2Fwww.freie-energy.de%2Fhtml%2Farchiv.htm&sandbox=1
MarkE
Filed strength is proportional to n*I.  If your goal is to obtain zero or near zero B by cancellation carrying a single current, then you have to match n in each direction.  Look up Aryton-Perry.
policiarj2
That is not the way in fact, the device oh Hans Coler does not use bi-filiar coils (Aryton-Perry), it uses two opposite coils to produce resonance:
Principle experiment of a ZPE-flux accelerator.
A copper coil which is crossed through the core. As a core can be used instead of iron and another metal, or a plasma stream.
The accelerated ZPE magnetic flux is directed to the right in the right-hand rule and the carrying core.
ZPE magnetic flux acceleration at current-carrying coil (iron core) = 100%
ZPE magnetic flux acceleration after 20 millisec. Cut-off = 93%.
When a pulsed coil flows through the magnetic field an accelerated decreases its power consumption.
Thus, the two opposed coils each magnetized with less power consumption.
Oscillator with two acceleration coils
Also referred to as non-inductive coil or Biström oscillator.
The two coils oscillators must be identical and equally strong.
You are connected as a bridge phases twisted together.
The magnetic cores or tube amplifiers operate as ZPE flux accelerator with pulsating direct current, not alternating current. Therefore, at least two separate magnetic flux accelerators are needed for a self-oscillating current generator, the pulses alternately as a bridge.
When a magnetic flux flows in parallel to an electrical conductor, the speed is multiplied.
When a magnetic flux flows in parallel to an electrical conductor, its electrons are loaded (doped), and generated from the particles present as Helion 1 and 2, a centrifugally accelerated magnetic (Protons) flow. Wherein the magnetic flux is concentrated and accelerated.
It arises in the conductor due to the excess magnetic Protons flow. This flow differs due to lack of space from the middle to both ends, moves according to the (right-hand rule) as a spiral around the conductor and radiates.
The two coils with a capacitor to vibrate at its natural resonance.
The two coils can be wound on a core side by side.
See cyclone generator:
The poling direction of the magnetic field is unimportant, because the field is flowing slowly.
The field from the next smaller particles (deutron) circulates inside as giving power.
The Double ball-and-egg cascade of crop circles.
The cascade is doubly symmetric, because it resonates as Biström oscillator, and both sides thus magnetized by a current flow.
The core, which should lead to accelerated magnetic flux
1 The tungsten coil found in Balbanju / Ural Russia consists of bundles thread-shaped tungsten geradelienigen crystal structures with a single thickness of the order of 1 micron. Behold: Phaser.
2 Ferrite.
3 directed soft iron (NANOPERM see MEG) www.magnetec.de / nanoperm_e.htm .
4 Electrically conductive permanent magnet (Alnico).
5 annealed and directed iron rod.
Non-inductive coils are connected as a bridge used in the current generators.
Rock on, and then produce itself current.
