Descripttime,
I may look but I can't guarantee it.  My instincts are telling me "No!"  I pay no attention to the whole open system/closed system argument.  Note the over unity claim was made about 20 years ago and still nothing.  That should tell you something.
Imagine you have an ideal inductor in your hands made of pliable wire with current flowing through it.  As you change the shape of the wire, that changes the inductance, and therefore the current flow has to change to respect COE.
You see that every time you watch a figure skating competition on TV.  While the figure skater spins they can modulate their speed by moving their arms in and out.  That's an analog of the ideal inductor mentioned above.
Angelic
So what your saying is that this is really a cult? Facts. engineering truths and alike do not really matter here. I'm wondering if Jamie part of the cult or just a tool?
Not in the traditional sense of what you would consider to be a cult. But it is a growing community based around personal spirituality. Frequency and resonance are key here as they are important elements in their spiritual path to enlightenment. This is why the QEG project is so easily assimilated and supported by so many around the world.
markdansie
Quote from: Angelic on May 20, 2014, 09:35:25 PM
I have seen this many times from the Joe Cell supporters and even the Mylow Magentic motor fan club. They act and behave like a cult in many ways. Sad but true, and cults are an easy way to pander the ego and scam for money.
Kind Regards
Mark
ACG
Quote from: MileHigh on May 20, 2014, 07:59:33 PM
PCB,
Here is a proposed posting for you:
Unfortunately this is a false alarm and the QEG is not producing over unity.  You do not use the peak-to-peak values for the voltage and the current to measure the power dissipation for the light bulb load.  The correct way to do it is to use one-half of the peak-to-peak values and then multiply them by 0.7071.  This gives you what is called the "RMS" (Root Mean Square) values for the voltage and current.
The power dissipated in the light bulb load is Vrms x Irms.
The reason you use RMS values is because this factors in the fact that higher voltages (or currents) give you disproportionally higher power dissipation levels.
1900 volts peak-to-peak, divided by two equals 950 volts.
950 volts times 0.7071 gives you 671.7 volts RMS
0.95 amps peak-to-peak divided by two gives you 0.475 amps.
0.475 amps times 0.7071 gives you 0.3359 amps RMS.
671.7 Volts RMS x 0.3359 Amps RMS = 226 watts
The electric motor is drawing 655 watts of power.
Therefore the efficiency of the QEG is 226/655 x 100 = 34.5%.
P.S.:  Rearranged one sentence and much better now.
And if opposition arises to the question of using RMS such as:
1.  We need to thing outside the box.
2.  That is the old wasteful oil cabal way of power wattage.
3.  Quantum does not work that way.
then state RMS is how the meter is measuring the motor power, in Watt mode as opposed to VA mode.  You trust RMS for the motor but not for the QEG?
Just in case, have that at the ready.
Another way of approaching the group is this, have them not use the kill-a-watt meter and instead manually measure the motor's power using the way they do, Peak to Peak.  When their erroneous calculation of a 240V 1000W motor (given power factor of 0.99) shows 7989W, what could the QEG group say to explain this away.
Angelic
You really need to take the time to review all of this information below.
FYI this is a quotes taken from this site. http://z13.invisionfree.com/HARD_Qs/index.php?showtopic=100
If you dig a bit, you will find that Naicheval Robitai, is Hopegirl's MOTHER (!!!)
So it seems she has raised money for a project "invented" by her father, or her mother's partner
Raising Money for a step-father's project.
: and not revealing the familial connection in the promotion - is NOT KOSHER imho!
This isn't funding a free energy project, its funding Hope Girl's bank account.
All about Hopegirl http://www.fixtheworldproject.net/about-hopegirl.html
Who's going to blow the whistle on her? For misappropriation of funds???
