0 Members and 45 Guests are viewing this topic.
jdsanders
This sounds like it's straight out of Tom Bearden's book.  Just sayin'....   8)
Quote from: Just..Sayin.. on April 10, 2014, 10:54:21 PM
The electrical current coming out of a generator has absolutely nothing to do with the torque applied to the generator shaft. The electrical output comes out of the supplied field which never runs down, and never runs out. The torque supplied to the generator literally 'goes out the window' due to the struggle between the supplied field and the induced field. Back emf has hypnotized people into thinking that the energy going into a generator is the energy coming out of the generator. This thinking is nonsense.
Electrical energy has never been conserved, it comes out of the supplied field over and over again, and it will continue to do so throughout eternity. The fact that we have always had to do a very relative amount of work to induce an electrical output is not relevant to the creation, or the transformation, of electrical energy that is taking place in the conventional generator.
There has never been conservation of energy in our generators and alternators. The supplied field, be it permanent or electromagnetic, pumps it out nonstop. There has always been an endless supply of electrical energy available. Unfortunately, it has always has required a relative amount of work to convert the supplied magnetic energy to electrical current output, because of the back emf encountered in the process. Find a way to get around the back emf and you have an endless supply of free energy.
Just..Sayin..
Quote from: hartiberlin on March 28, 2014, 08:41:55 AM
If you look closely the WITTS Demo by T. Thrapp shows, that the motor does NOT slow down
when the screws in the bulbs... at minute 7:30
This is the best evidence for a fake...the motor speed
should change !
Regards, Stefan.
Not so fast Stefan, no back emf, no slow down.
Just..Sayin..
Quote from: jdsanders on April 10, 2014, 11:20:08 PM
Perhaps it is, I have never read much of Tom Bearden's material but he probably got it from me through Bill Muller in Penticton BC. Back in the early 80's I was working with Bill Muller building stationary armature generators that were the forerunners to Bill's efforts to drive the rotor with the induction coils. Bearden and Bill became friends after I left the venture.
Bill and I ordered four of John Ecklin's cores at that time and were experimenting with them when I had an idea to mount them all together and stagger the frames to eliminate the static losses on the iron rotors. The Ecklin core/rotor setup of course, is similar to the QEG. We never had any success with Johns design, but we only utilized a minimal amount of windings and never had any notions of mechanical resonance.
Imagine you had a setup with a handle connected to a gearbox so you could crank it with your arms.  The output of the gearbox drives a generator connected to a 100-watt light bulb.  When the light bulb starts to light up you will feel the extra mechanical power you have to supply with your bare arms.  It's actually almost shocking to see how much torque you have to apply as the light bulb gets brighter.  That's the way it works.
The way these stories are so far fetched sometimes it's incredible, except it really happens.  I read the snippets of the guy talking about running his 90-minute test supposedly driving 4 kilowatts.  In 10 sentences or less he could have described how he took the raw output from the QED and then used a transformer to drive a load.  What transformer?  What load?  So you interview the 'tech' guy and he has noting substantive to say at all about the output section and the load and his test and his voltages?  ha ha ha
And just as shocking all of the 'replicators' are probably not talking about this either.  The "500 watt load 1000 watts in" clip looks like somebody just playing with coils and discovering them for the first time.  At least from the glimpses that I saw.
You almost have to be 'crazy' to promote this thing and never once having tried to produce a useful output.  Is the output high frequency or is it 400 Hz, I think I read both.  If it is 400 Hz then there must be stuff available off-the-shelf because they use 400 Hz power in aviation.
It's a new Invasion of the Body Snatchers!  Mass hysteria!
