0 Members and 87 Guests are viewing this topic.
Farmhand
Resonant rise can be useful, ie. if we have a very low voltage low current low power supply and we want to apply a higher power to a load intermittently, then we might use a resonant tank and apply small power input until the desired voltage or power is achieved then tap the energy in the tank so as to intermittently apply a much higher power to the load than is possible with the low power supply. However the energy in the tank will decrease suddenly and rebuild slowly.
Or when the power namely the voltage portion reaches a suitable level an attached load that requires a certain voltage with little current can be powered continuously while limiting the tanks oscillating energy. Tinsel showed this. Resonance could be useful in energy scavenging.
Quote from: Eniac5state on Today at 09:21:44 AM>
QuoteThe LC cicuit consists of two main coils and a capacitor bank. The coils are 40 H each and the capacitors together make 125 nF.
That makes a resonance of 50 Hz !!  Of very high voltage also !
And MarkE replied:
40*125E-9 = 5E-6, 1/(2pi*5E-60.5 = 71.2Hz.
Which curiously is very close to the frequency shown in the scope shot.
However, if one uses "80H" in the calculation instead of 40H ... since there are two coils... one arrives at the resonant frequency of 50 Hz ( 50.329 )  as noted by Eniac.
Are the coils wired in the tank so that their inductances add, though? This is not clear to me.
http://www.1728.org/resfreq.htm
Eniac5state,
Myself and Farmhand are not shills.  In contrast, HopeGirl is the main shill for the QEG project.  It's a band of merry pranksters on a magic bus.
Turn on, tune in, and drop cash.
TK:
The two coils that make up the inductance for the primary tank circuit only work together when the spinning rotor is lined up with the extra inner "posts" that form the core.  That routes the magnetic flux in an additive way.  When the spinning rotor is not lined up with the "posts" the magnetic flux from the two coils will be in self-cancellation.
Quote from: MileHigh on May 31, 2014, 08:55:51 AM
Eniac5state,
Tune in, turn on, and drop cash.
Right. There's an undertone in the most recent set of money-grubbing lies from HypeGirl, too. The affair is beginning to fall apart; even people who don't understand the electrical engineering issues are beginning to notice that the Emperor's ass is hanging out in the breeze. That is... the early claims of free energy, self-running and all of that were clearly not true and it's also clearly not true that the QEGers have the knowledge that they are trying to sell via the "consulting" bit. Offering for sale something that is not actually possessed is a real crime in many locales.
Hey, James Robitaille! If you ARE reading here, why don't you contact ME. I'm offering my services to you as a consultant, and my fees are only 2/3 of yours. So you can take my advice and re-sell it for a profit! I actually DO have the knowledge and skills and even the materials to provide you with some very important advice.
I can teach you how to use your oscilloscope to obtain accurate and precise readings, and how to use its advanced math capabilities. I can teach you the proper use of the AC-coupling feature of your scope, how it works and why it does what it does, and its effect on computations derived from the trace values.
I can teach you how to display your data effectively.
I can teach you how to set up a spreadsheet for recording and reporting your data... using a text "word doc" for that is just...er.... inefficient (and silly).
I can teach you basic HV bench safety.
I can tell you how to find and use the _correct_ capacitor types for your project. I can even _sell_ you the correct capacitors from my stock. (Strontium titanate doorknobs rated 30 kV each, which can easily be stacked in a series-parallel stack to obtain the correct value with low losses, and immersed in oil for safety and further isolation.)
I can teach you how to make and use an effective spark gap, and how to protect yourself from the UV, X-rays and toxic nitrogen oxides that it will produce.
And more... I can even invoke the name of Nikola Tesla and _properly_ apply some of his principles to your project.
And I can do all of this without needing airfare, hotel accommodations or restaurant meals. I just need some of that nice juicy cash you lot have been raking in with your false claims and incorrectly interpreted data from your unsafe, ineffective, noisy and expensive kludge. Er, sorry, I mean your Tesla QEG Free Energy Generator.
Send me a PM, Jimmy. It's clear that you are in way over your head and you really _REALLY_ need some good advice. You may be able to save some face, if you start your damage control now.
