0 Members and 87 Guests are viewing this topic.
mscoffman
It is clear that a physically disk shaped generator can intercept signicant amounts
of static electricity from the environment. Even more if one was to add a long
antenna wire. Once it is intercepted it can be used to enhance the current flow
in the field coils of the generator thorugh the use of capacitors which will have
a direct bearing on the power output by the generator. There is so much
enhancement that it appears it would be difficult to entirely supress this effect
in a normal generator design. This means that various commercial generators will
almost certainly show *some* enhancement of their output level based on the
detailes of opportunistic physical design criteria qmogen operation exist in certain
cases.
It is clear that a horrendous miscount in the number of turns of wire on the coils of
the QEG generator has led to the fact that the labels on the primary and secondary
coils were initially interchanged. The first effect of this is that the #10 gauge wire is not
necessary and that a unitary wire gauge number could be used throuhout the entire
QEG generator to good effect. Next is the probablity that tuning will require both sides
of the QEG to have capacitors and both sides to have dummy load lightbulbs. This means
that power will be extracted from both sides of the QEG. So with  the QEG one abandons
the concept of a stand alone AC generator, but that it is an excellent  *a power source*
powering an HV DC- AC interter to produce output and self-loop energy.
The way to combine both coil sets power into one is to understand the electronic
concept of "center-tap" with a center-tap operation the output voltage will be halved
and the fast HV rectifier bridge will require only two diodes. The lightbulb voltage should
then also be halved. The rectifer bridge and 3000uf capacitors with adaquate working voltage
as measures on the lightbulbs should be asserted so that both the voltage and the current
and DC and have vanishingly small AC ripple. Then the two coil sets DC can be combined
and connected in series and the voltage of both sides summed and the current of both
will be summed.  All of the lightbulbs can then be moved to the net DC circuit. A DC sides
voltmeter and a DC milliamp meter with a 1000:1 current shunt can be used to measure
voltage times current and DC power computed both readings. Note that by measruring
power in DC, all argruments associated with Power Facter, Vars, RMS, voltage vs current
phase, and AC instrument accuracies, and insane agruments about AC waveforms goes
away, eaten by diodes. Current transformers cannot be used with DC, and shut resistance
used instead beacuse current is now DC and won't flow though current transformers.
Once this has occured one can substitue non-inductive power resistors for lightbulbs and
carefully tune the system again but this time maximizing *computed* DC power readings.
When the system is alligned for maximum power output one should expect this to be
OU over input. One should note the total load resistance as this is the resistive *output
impedance* of the QEG power source.
The system will be ready to have power directed through a high voltage DC-AC (solar)
inverter to power the input motor with extra energy left over to be dissipated in resistive
(wind power) dump load resistors or directed out to power the ever-hungry power grid.
At this is the motor driver self  looping effect.
Note that the above has been done without varying the QEG wire turn counts which could
still be done to good effect for output power. But I expect that the QEG will now be well
overunity withgout it.
:S:MarkSCoffman
Pirate88179
Quote from: mscoffman on May 31, 2014, 11:15:34 AM
:S:MarkSCoffman
You can't be serious?
Shanti
QuoteYou can't be serious?
I wanna have the same drink, as he got... ;D
But seriously mscoffman:
Did you ever test out anything of what you're theorizing?
It seems to me your mind has wandered far off the experimental evidence... ;D
(the mind often likes to do that... ;D )
Actually, it is quite easy, at least to make a basic QEG setup.
And quite some experimenters already did. But all had to conclude: No OU.
But I encourage you, to replicate it yourself and show us all  that your theory is valid.
Maybe it is...
ariovaldo
Good morning !!
As suggested, I made a test in my QEG device, adding a mechanic commutator in series with the load.
As TinselKoala said, this was funny to see....a lot of sparks...
Enjoy
https://www.youtube.com/watch?v=H2V5n_zZYnI
No values for now. This was just to see the effects.
Cheers
Ariovaldo
Rigel4
That's a nice rig, good work. I hope you are doing this for fun and to learn, not for OU. Since Hope is now claiming 33x, it will be nice for a control like yours.
Thanks
