Just one little example of releasing reactive power (stored resonant energy) as real power:
ariovaldo
Quote from: TinselKoala on May 31, 2014, 05:32:09 PM
Yes... you are now seeing what power arcs can do as opposed to mere sparks.
You can see in the video how the commutator segments are dragging power arcs from the brushes, across several segments. This of course means that the commutator isn't interrupting properly nor addressing the coils in the proper manner or timing. It also means that material of the commutator is burning, and you will have pitting, metal erosion and deposition, and the rough surface thus presented to the brushes themselves will ruin them.
These power arcs are formed by the heavy inductances trying to remain connected as you try to disconnect them. You could try a powerful blast of compressed air onto the commutator with the hope of blowing out the arcs, but with as much inductance as you are switching even this will probably fail.
But I do like your multi-element primary spark gap. This will work much better than the QEG team's silly automotive spark plugs, even if they are platinum. Add elements for even more effectiveness. One of the very best performing stationary spark gaps I have used is an original Tesla design: it's made of six heavy and thick nickel washer-like cylinders, stacked on an insulated shaft, with a small gap between each flat cylinder face. Again, blowing with compressed air can help the effectiveness of even this gap by blowing out the spark to produce rapid fall times in the current through the inductors.
8)
Commutator and high voltage doesn't work good. It looks like a 400 HP dc motor out of position ( Point of commutation), Probably if I change the secondary, 30 turns of ticker wire, (1/0) for example, it will work better. After that, just a step up transformer.....I don't know...just wondering....
wayne49s
There are various circuits out there that are suppose to convert the reactive power to real power from the rotoverter device information (you can do a search on this).  The principle is one based on extracting through voltage (capacitor charging) and drawing power from them. Note that voltage is a maximum when current is at a minimum (charging interval near voltage maximum), so BEMF is minimized in terms of impact back to the source, i.e. the motor turning the generator.  Also, it is desirable to extract the power from the capacitor when it is not being charged, so this is another way not to impact the source current draw.
As I understand it, not all the reactive power should/can be withdrawn as it would kill the resonance.[size=78%] [/size]
[size=78%]
[/size]
In any case, I believe the QED may yet show OU.
ariovaldo
Quote from: TinselKoala on May 31, 2014, 07:57:23 PM
I had a lot of that....hard way to learn, but at least I learned a lot of: " don't do that"   :-[
Angelic
ACG,
I hope that you understand that my post that you referenced was directed toward Hope and the spiritual spin that she is using to further her agenda. She may be the acting editor/producer of everything that is released concerning the QEG. I am no fan of hers..
