Quote from: ariovaldo on May 31, 2014, 07:58:29 PM
Commutator and high voltage doesn't work good. It looks like a 400 HP dc motor out of position ( Point of commutation), Probably if I change the secondary, 30 turns of ticker wire, (1/0) for example, it will work better. After that, just a step up transformer.....I don't know...just wondering....
It's not the voltage that kills you... it's the current. Same goes for the commutator. After all... the power arc is essentially a low-resistance short circuit, there will be only a small voltage drop across it.
Khwartz
Quote from: MileHigh on May 31, 2014, 07:19:03 PM
Khwartz:
As you can see I answered in my previous post.  It has nothing at all to do with "concepts I have learnt."  It's just basic nuts and bolts that a good kid in Grade 8 physics class could easily understand.  It literally is as trivial as kids passing pennies to each other.
I know my domain reasonably well and I am 100% certain of what I am stating.  Just search on "LC resonator" or "LC tank circuit" if you want to get some more information.
MileHigh, undestand me BETTER: I am not saying that indeed in the case of these experiments it does occure and there is an infinite "source of pennis", to take your words.
I know about tank energy and resonance, you teach me nothing new about that, expect if specifications for electronic or electromechanical way to extract the energy stored in the tank.
But I confirm you are obviously stuck in your own learnt concepts when you can accept nor apparently imagine that an infinite source of energy could feed an energy tank. This is precisely what is going on in an heat pump but it needs to know in with boundaries we place. I will not essay again on this subject, just read please my post on COPs for more details.
As for Farafay, Maxwell, Dirac or Tesla, the said "vacuum" is not empty but full of energy and I see no evidence it would not be possible to harvest it.
Cheers.
Khwartz:
I suppose you could say it boils down to the issue of the physical QEG itself.  Is it just a normal circuit or is there an infinite source of energy feeding the QEG's LC tank?
The answer is that it is a normal circuit and the concept of an infinite source of energy feeding any circuit is just a hypothetical.  There is no reason to link this hypothetical with the QEG.  If someone wants to research this hypothetical concept then fine, but not with a QEG.
To pitch to the world that you have a free energy machine like the QEG is wrong and the test results from the QEG team so far clearly show there is no over unity.  They don't want to state this fact directly and instead play a game of smoke and mirrors with the results and the promises.
Khwartz
Quote from: MileHigh on May 31, 2014, 07:51:32 PM
No need for a link.
For starters, to be specific and to not induce any misunderstandings, it's accumulated resonant energy, not accumulated resonant power.
1.  Connect a resistor across the terminals of the capacitor.
2.  Put a coil next to the tank coil and magnetically couple the two coils together.  Put a resistor across the new coil.
You can think of the resistor in either case being like applying the brakes on a moving car to slow it down.  To be more specific, it would be like a "damper."  A damper resists with more power the faster you are moving, and likewise resists with less power the slower that you are moving.  Like how a car shock absorber works.  The net result in an ideal case is that the damper can never actually make the car stop moving.
Very thanks for these new specifications.
Understand when you say the exchange between the two opposite parts of the tank is not power in the sense it couldn't be used and sustained simultaneously, but still as a flow in can be calculated in terms of energy by unit of time, not consumed, we agree, but indeed exchanged.
Isn't your analogy of the damper like what I said about to realign the phases between current and voltage by shifting one or both? But would be odd to me cause a resistor is not supposed to shift any phase? So, would the resistor would be more like a barrage on a river not letting floods occuring but delivering only the flow we need?
Could you upload a schematic, even handwritten, of example of transformer circuit?
Khwartz
Quote from: TinselKoala on May 31, 2014, 07:52:09 PM
Mile High is exactly correct. The analogy that I used before, of the little girl on a swing, should be recalled and considered. You give the little girl a slight push each cycle in time with her swinging and the amplitude of the swing increases to scary heights.  Measure the maximum heights of the swing: this is your Peak-to-Peak reactive power. Do you want to extract it? Go stand in front of the swing; when it hits you, you will get all that stored energy dumped into you as real power. Do you want to use the power at a reasonable rate? Fine, you can extract it no faster than it is being resupplied by the per-cycle little pushes.
Bottom line: utilizing reactive power is no big deal. Utilizing it at a faster rate than it is being replaced by the input... and your resonant system will collapse.
TinselKoala, I do agree with you both on that point and never said the contrary. I was just going further than this and in this case all is about the possible connection to an infinite reservoir (NOT necessary in this experiment).
To try to use your analogy, it would be like if when the swin reaches a certain height the girl would have time to take big fruits on the tree and gives it to someone at the lowest height. If done continously,  the swin could go on indefinitely while an flow of particles, here the fruits, occurs.
Of course here the tree wouldn't be "an infinite reservoir", but the Ditac's plemun looks to be...
