Eligos
vince
Great test Luc!
The question I have is, does the drive motor experience any greater load when you reach resonance points or when the secondaries see a load. I realize that you have not run the unit long enough to see any power output but it will be interesting to see if the drive motor sees a greater power demand as in conventional generators under load.
Keep up the great work!
Vince
Quote from: Paul-R on April 11, 2014, 09:54:12 AM
This is quite true if, and only if, energy is not being introduced into the system from an exsternal source which is known (solar panels) or not well known (quantum foam etc).
This drills a hole in the bottom of your boat, Milehigh.
"IF" perhaps, but not "only if".
If the generator is already producing its full possible output, and you simply make some of that output visible by making it light up some lights, would you still expect the generator to change speed or require a different amount of drive power?
jbignes5
Quote from: gotoluc on April 11, 2014, 09:32:28 AM
Hi everyone,
as I have posted a few pages back, I've been testing the effects of the QEG.
It coincides (like woopy) I have also thought of using a MOT for its high Inductance coil to see if I can produce some of the effects claimed.
I can confirm that there is a real effects and I would strongly suggest to the naysayers to hold off on your critics as you may end up having to eat your words. Best to put your energy in experiments as this looks to have real potential.
I made a video demo of my setup so you can see that I'm not just talking. However, I did not feel comfortable to demonstrate the Resonance as my particular test setup may not be able to handle such vibrations. When it first happened it scared me and I quickly pulled the plug as my 100 pound safety box was vibrating like a jackhammer.
Of course I'll be doing more tests but I thought to share my test rig and basic findings.
Link to video: https://www.youtube.com/watch?v=NLiZDQxywqE
Stay tuned for more
Luc
You need to have an output on these devices! You can not run this device without a load. The load is designed to not let a buildup of too much pressure. This is the shaking you are seeing. It is building up more energy then it can dissipate and then leaks to other effects like shaking. It's like blocking certain type of pumps. They will explode if they have no output release. Most have a safety release just in case of a short or block occurs. DO NOT RUN THESE TYPE OF SYSTEMS WITHOUT A RELEASE OR OUTPUT!
The output has to be isolated from direct shorts. On way is to have an isolation transformer to protect from load shorting. Transformers are one way to isolate a load from source but even spark gaps and the likes also do this. So the choices are many.
shinz62
Luk - great idea!
Finally someone who wants to take a step of faith.
There can be no progress by sitting back and throwing stones.
I just have to say Luk, what is going to happen is that once you get some more power running through your coils and transformer cores become more magnetized momentarily during each cycle it is going to start grabbing harder and this is where all the incredible vibration you spoke of must be coming from considering the tremendous torque of that motor you are using. If don't keep the power levels exactly the same in each core they may start touching down and it will be like disc breaks. I can see why it might get quite frightening. For safety sake I would not necessarily recommend pushing this particular design much further.
I was thinking about something Timothy mentioned... there was no fly wheel and the relatively small rotor was coupled via a belt.
I believe his configuration was chosen for that very reason, to provide give to the grab.
The belt provides additional "capacitance" due to its elasticity.
This results in a physical energy store and release cycle between the belt and drive motor that will have its own resonate points.
So they have two energy store and release systems each with their own resonant points.
I believe the trick is to synchronize the two resonant systems to feed back on each other.
Food for thought.
Thanks!
