0 Members and 89 Guests are viewing this topic.
albert
Hi to everyone here on this thread,
I have been following this discussion for a while. MileHigh you are indeed correct in assuming that many people from other forums are following the discussion here. The problems with the marketing and publication strategy of the HopeGirl group are being discussed to death. I would very much like to leave this out at the moment and focus on the technical questions.
Now your last piece about reactive power was clear and concise. Well explained "for dummies."You took a motor as an example.
"If the power is bidirectional where power flows from a power station into an electric motor, and then half a cycle later power flows from the motor to the power station then you have a reactive power situation.  The power that the motor sends to the power station did not come from the motor itself, it's just the power station's originally supplied power being kicked back by the motor."
Clear and agreed upon!
I have read about transmission lines, power being reflected to the source.
Do you agree with me that the reactive power situation corresponds to a standing wave situation in the wire? You are getting an interference pattern with voltage and current nodes. The energy reflected back to the source interferes with itself. This might heat up a transformer because it might be in a place where it basically has DC flowing thru it.
Do you agree that a standing wave phenomenon can happen at any frequency and is not limited to RF?
Do you agree that in a standing wave situation the GEOMETRY of the output circuit comes into play? Different values for voltage and current can be read in the circuit at different places.
This means that in a series circuit the lamps could be unevenly lit although they are...in series.
what I want to know is whether the Tesla Hairpin Circuit or the "Lecher" circuit can be applied here to extract energy.
I am also thinking about a LASER type phenomenon where you pump energy into an optical or electrical resonator and get coherent light at the output that does not occur in nature and has different capabilites from  normal light. A laser is under unity but no one can say this discovery has not changed the world nonetheless.
think about a magnetron...resonant cavity...if you look at the history of RADAR the importance of resonance and GEOMETRY of the resonator was the key to unlock the shortest wavelengths.
There are so many cases where the geometry is of utmost importance. A lens concentrates light. A prism splits light into its components. Who can say we have reached the end of possible discoveries in the electrical realm?
Now the components of the QEG hve all been researched and have been known for ages. There is however a possibility that a new combination of components may lead to a discovery.
If these thoughts come from the "QEG Twilight ZONE" I apologize. But perhaps its food for thought.
PiCéd
Yes the Qeg is all reactif for now, but if they have there variac is the input power will stay to 600 watts or it will rise to almost 2000 ?
Unfortunatly I think it will be 2000 watt input if all the reactive power become active...
MarkE
Albert, perhaps this will make things even simpler than MileHigh has already explained:
Reactive energy is energy that is stored.  Reactive power is the rate at which energy is moved into and out of an energy store.  Resonant circuits shuttle electrical energy between electrostatic potentials:  charge stored in a capacitor, and magnetic potentials:  the magnetic field surrounding current.  A resonant circuit that has a high quality factor: Q, loses only a small fraction of the stored energy on each cycle from maximum voltage across the capacitor to maximum current through the circuit and back to maximum voltage across the capacitor.  Such high Q networks can collect up a lot of energy a little bit at a time.  All energy that is directed into a resonant network from some source is energy that is not applied to a useful load.  If the network is high Q then most but never all of the energy diverted into the resonant network is available to return to the source or perform useful work.
Reactive components and resonant networks made from reactive components:
Store energy.
Dissipate some energy.
Can build up very high voltages and/or currents.
Can release their stored energy at much higher instantaneous power levels than the energy was input, or vice-versa.
Do not create energy.
Do not amplify energy ( same as saying they don't create energy ).
Khwartz
Quote from: TinselKoala on May 31, 2014, 10:23:44 PM
No worries, mate. The Revolution-Green site has some pretty good information about QEG and the early days:
http://revolution-green.com/
Meanwhile, fwiw, here's the operator's manual for the TDS3000 series scopes, including the TDS3054. I was hoping it had an actual image of the Probe Setup menu but it doesn't go quite that deep. This is where the probe type (current or voltage) is set and its attenuation value. They could have set Voltage x1000 and Current x10 here, and the onscreen display labels and values would then be correct. It does also show how to set the math trace to multiply the V and I traces, and it shows how to set up the Measurements to display RMS values for any trace.  In other words, the manual for the scope Robitaille is using clearly explains how to use its basic and advanced features, and this manual is available for free on the internet.
Every engineer knows the meaning of the initials "RTFM". Don't they?
http://courses.cs.washington.edu/courses/cse466/07wi/labs/l2/Oscope/TDS3000Manual.pdf
Thanks TinselKoala for these new data.
I paying my studies and family needs, while working as independent electrician from other professional activities I have, I've trained me in this job in this financial purpose, but I have a very basic training in and I am not skill in anything in oscilloscopes and even more in electronics. I am more about the "genie énergétique" we say in France (energetic engineering) and study of Sciences in general, their history, "genetics", methodology, and logic. So, I am afraid that these technical data you provide to me, I won't be able to use it before long cause my own job and studies already take more time than I would wish.  lol But thanks for your attention, anyway :) Only have very basic Vellam PSGU250 combo scope+gen home.
For the scam possibility, I recognise there is very good argument to think it is, or they are not technically enough educated and they have too much "enthusiasted" themselves. But indeed when I checked about WITT demo, I thought it was a scam while the house was not powered by the system while they claimed it was working from long time, and yes, the vid could be faken with a power grid wire at the back of the blue box on the top of the bulbs panel :/
But I mind: WHAT THE PEOPLE WHO HAVE MADE DONATIONS TO WITT SINCE YEARS FOR THEIR SAID "FREE ENERGY DEVICES", DO IF THEY'VE DONATED BUT HAVEN'T THEN ANY ACTUAL WORKABLE DEVICE? I am surprised to not find any record of complains against them on justice court, this puzzle me so.
Pirate88179
Quote from: Khwartz on June 01, 2014, 12:41:38 PM
Yes, exactly what I thought when I first saw their first demo.  Here you have this source of endless free energy that you are "selling" (donations...) to others and yet, you are still on the grid.  That was my first big red flag.  Then, when Stefan Hartmann (Our gracious host of this website) payed money to interview them, and all they gave as far as info goes were overunity generalities, theories, etc. I knew it was a scam.  So, when Dopegirl, et al, sites Witts as the inspiration for their device, and praises their brilliant work, another huge red flag was raised.
I have no idea why folks that "donated" to Witts have not taken action against them and I don't understand why Dopegirl is not being sued either.  I guess folks just want to believe.  Very sad.
