0 Members and 86 Guests are viewing this topic.
MarkE
Quote from: Marshallin on June 03, 2014, 10:05:07 AM
Hi,
guys seriosly, so far i dont see any real test about QEG.
Lot of people here have laboratory grade eqipment at home and just flame here and argue about nothing.
Is realy so hard for you to make small scale replica and test it? Maybe it work maybe not.
But you cannot claim stuff until you realy test it.
No that is not true.  Many things can be analyzed adequately on the back of a napkin.  Others require more detailed analysis to resolve.  Few things require physical experiments to prove that the status quo is correct.  It is always the burden of those making an extraordinary claim to produce evidence commensurate to the claim.
Just think about it, vibrating laminted steel shout not produce so much electricity at all acording current physics !!!!
Magnetostriction is well understood.  FTW have not shown any unusual behavior from magnetostriction.
Can it produce more energy then consume? Who knows?
I do:  It doesn't.
I am not telling that QEG "hope girl" team have full funcional OU device. Probably they are bunch of fakers. But still idea may be usable.
It isn't.
btw, i found new joke from them : https://hopegirl2012.files.wordpress.com/2014/05/morocco-qeg-june-2014-test-and-measurement-report-v2-011.pdf
that has been circulated.  It's crap.
Marshallin
Quote from: MarkE on June 03, 2014, 10:24:47 AM
No that is not true.  Many things can be analyzed adequately on the back of a napkin.  Others require more detailed analysis to resolve.  Few things require physical experiments to prove that the status quo is correct.  It is always the burden of those making an extraordinary claim to produce evidence commensurate to the claim.Magnetostriction is well understood.  FTW have not shown any unusual behavior from magnetostriction.I do:  It doesn't.It isn't.that has been circulated.  It's crap.
"Magnetostriction (cf. electrostriction) is a property of ferromagnetic materials that causes them to change their shape or dimensions during the process of magnetization." ....
Durning rotation core dont change shape.
You know? How? Looks like you just read somethnig somewhere .... between thnikning and knowing is big diference.
Again you claiming somethnig without any proof. You act absolutly same like "hope girl" team.
MarkE
Quote from: Marshallin on June 03, 2014, 10:39:44 AM
Magnetostriction also occurs in non ferromagnetic materials when they carry current perpendicular to a magnetic field.  There are any number of loudspeaker designs that capitalize on that fact.
I know.  Don't believe me?  Come up with evidence that I am wrong and that FTW's contraption can ever generate surplus energy.
You are victimizing yourself with the fallacy that the known and ordinary are equally likely as the unknown and extraordinary.  Our vast experience that has led to the formulation of First Principles tells us that there is no energy surplus to be had.  That has been confirmed with countless experiments on other machines and FTW's experiments on their own contraptions.
PCB
At the point of resonance a large amount of energy is built up in the primary tank circuit, leading to strong magnetic fields being generated. As already mentioned this gives rise to two things. Magetostrictive forces and Mageto-motive forces. Since this is a variable reluctance device I suspect that the Mageto-motive forces are quite large coursing significant movement of the core laminations. The QEG appears to experience considerable vibration at resonance which kind of supports this idea. The QEG is a very heavy piece of gear and a lot of energy is going into those vibrations, perhaps several hundred Watts or so. We do see the input power jump up at resonance.
See https://en.wikipedia.org/wiki/Magnetomotive_force for the equations.
