Look. Here's the logic behind self-looping with no outside power source.
Measurements made on many different FE devices indicate more power output than input. Great! We've all seen these devices in many different forms in many different YouTube videos, some more plausible than others. Not one _plausible_ and confirmed case of self-looping has happened, though. (I know some of you disagree with this; the problem of explaining Big Oil and Fracking is left to you folks then.)
So, many people believe that the measurements that indicated those big power outputs are somehow flawed. Especially since many of the claims are of such great powers that even the inefficiencies of standard generators or inverters would be easily overcome, to make a net excess power output.
There is one _sure_ measurement that can be made, though: Self-looping. If a "free energy" device produces a _claimed_ power output in excess of the simple losses in a generator or inverter.... but can't be made to self-loop, there is no doubt about it: the measurements of excess power are flawed and there just isn't any.
The electrical power output is weird in some way, longitudinal scalar vortex funnels or something? The mechanical power output is in the form of chaotic pendulum swings and chains of floats in mercury? No problem, really ..... making the input-output interface, even for such difficult forms of output, is "just engineering" and can be solved. IF, that is, there is really excess power in the first place.
In the QEG, whether from Thrapp or Robitaille..... there isn't. You won't see it self-looping, that's for sure, and you won't see any genuine sustained power output that's greater than the power input to the drive motor and "resonant" coils. You will, however, see a lot of money changing hands, and you'll see WhateverGirl and her minions getting a lot of free vacation time.
And here's the kicker: other than "self-looping", there is NOTHING about any of these devices that is contrary to well-known physics principles! That makes them uninteresting UNLESS they can be self-looped!
woopy
Hi all
After getting some voltage by tapping the core of the MOT, i tried as GOTOLUC, to test  if the inductance switching can also create a stable voltage. And it seems to be the case.
Than i tried to shortcut the coil, and it seems that the prime mover does not draw more current under load??
Is this voltage creation Lenzless ??
http://youtu.be/IssMkABzWD0
voila
Laurent
gotoluc
gotoluc
Quote from: jbignes5 on April 11, 2014, 11:45:37 AM
You need to have an output on these devices! You can not run this device without a load. The load is designed to not let a buildup of too much pressure. This is the shaking you are seeing. It is building up more energy then it can dissipate and then leaks to other effects like shaking. It's like blocking certain type of pumps. They will explode if they have no output release. Most have a safety release just in case of a short or block occurs. DO NOT RUN THESE TYPE OF SYSTEMS WITHOUT A RELEASE OR OUTPUT!
The output has to be isolated from direct shorts. On way is to have an isolation transformer to protect from load shorting. Transformers are one way to isolate a load from source but even spark gaps and the likes also do this. So the choices are many.
I had 2 light bulbs as load.
The limitation with my simple test design is the rotor I cores hit the E cores when resonance kicks in. This causes a braking action.
I will have to come up with a new heavier design that the rotor will not flex under resonance.
Luc
gotoluc
Quote from: shinz62 on April 11, 2014, 12:00:22 PM
Luk - great idea!
Finally someone who wants to take a step of faith.
There can be no progress by sitting back and throwing stones.
I just have to say Luk, what is going to happen is that once you get some more power running through your coils and transformer cores become more magnetized momentarily during each cycle it is going to start grabbing harder and this is where all the incredible vibration you spoke of must be coming from considering the tremendous torque of that motor you are using. If don't keep the power levels exactly the same in each core they may start touching down and it will be like disc breaks. I can see why it might get quite frightening. For safety sake I would not necessarily recommend pushing this particular design much further.
I was thinking about something Timothy mentioned... there was no fly wheel and the relatively small rotor was coupled via a belt.
I believe his configuration was chosen for that very reason, to provide give to the grab.
The belt provides additional "capacitance" due to its elasticity.
This results in a physical energy store and release cycle between the belt and drive motor that will have its own resonate points.
So they have two energy store and release systems each with their own resonant points.
I believe the trick is to synchronize the two resonant systems to feed back on each other.
Food for thought.
Thanks!
Hi shinz62,
You are correct!  my design becomes a disk brake at Resonance.
I like your understanding of the possible use and work of the belt. I'll incorporate it in the next design.
Thanks for sharing
Luc
