A little waxing poetic with Stuart on PESN:
What you and many others are in denial of Stuart is the rational analysis of a circuit.  Look at the QEG schematic, there is practically nothing to it.  You literally just have to look at it to know how it will work in the energy scheme of things.  Then the QEG team shared some test data and it corresponded exactly to what the rational analysis says it should have been.  And that's the great tragicomic underbelly to this story and many other stories.  This subtext is almost always there, electronic circuits doing exactly what they are supposed to be doing in a spin zone of a vortex that sucks people into the free energy narrative.  Right now as we speak, all of the QEG data is saying this is just a hunk of metal and wire.  There is no "magic cycle" that you can show on a scope display that shows a small low-energy pulse in and a large high-energy pulse out.  They literally will never be able to show this on their DSO because it is simply not there.  The way caps, coils, and transformers work is known and understood.  Almost every pitch like this relies on a supposed "magic pulse cycle" with more out than in.  But they never show it.  Literally hundreds of proposed free energy circuits and devices relay on this supposed "magic pulse cycle."  If it really is there, you should be able to show exactly where it is.  You should be able to pin-point it right on your scope display.  You don't have to explain it, just showing it actually exists would be good enough for starters,  But you never see it.  Almost like a dance of the absurd.
Let me state it like this:  Every motion, every interaction, every voltage, every current is absolutely real and doing exactly what it is supposed to be doing.  There is no "portal" happening somewhere in the rotor's rotational cycle that is "letting energy in from somewhere else."  It's just a pile of metal and wire, it simply will not happen.  There is no denying the reality of how the circuit works, period.  No matter what somebody says.  That leaves the proponents in the "Burden of Proof Doghouse."  Show something extraordinary with no hype and no pantomime and make your proof extraordinary, or remain in the Doghouse.
Now, on the other hand, if you have a team of engineers working on the QEG, they should easily be able to identify the "magic pulse cycle."  They have all the equipment.  It it actually worked, even a bench technician should be able to identify the "magic pulse cycle."  Then we are back in the dance of the absurd territory.  How many QEG engineers does it take to construct and analyze a QEG timing diagram?  Answer:  0 + j21.
F_Brown
Miles,
Just what is it you want to see in a timing diagram?
I got this:
Purple is the voltage across a 2k resistive load in series with the primary.
Green is the rotor angle.  I ramp it four times from 0 to 90 degrees in the model to simulate 360 degrees of rotation.  The rotor angle is read on the volt scale in degrees.
Red is current through the primary.
Blue is torque on the rotor shaft.  Torque is read on the volt scale as newton meters.  Negative torque equals load on the drive motor.  Notice that the torque is mostly negative, meaning there is a lot of load transfered to the drive motor.
F_Brown:
Anther fascinating simulation.  I am only glancing, it's late.
What the builders of the QEG have to do is first demonstrate over unity for real, not the nonsensical foolishness and lies taking place right now.  Right now is like a bad pulp sci fi novel where there is a fatal flaw in the premise of the whole society.
Measure the input power flow over a single cycle.  Then measure the output power flow over a singe cycle.  Explain the waveforms in detail.
If you haven't achieved over unity do it just the same because that is exactly what you are supposed to do anyway.
Now the QEG is a slightly different beast, there is no set of electrical input waveforms.  That doesn't matter, you push forward nonetheless.  You look inside the QEG and find the waveforms that are as close to the input as possible and go from there.  Since the circuit is so simple, you will end up analyzing the entire guts for the QEG, so much the better.
If you are going to be real, and considering how ridiculously simple the circuit is, the logical thing is to analyze ALL the guts and audit the power trail, and at the same time you could be leveraging the power of your simulation.  Anybody that is a real engineer and is serious would have to analyze this thing inside-out and it will not be that difficult.
It's a quest for the Magic Pulse Cycle and you leave no stone unturned.
http://pesn.com/2013/08/03/9602351_TMR-Effect--Tunnel_MagnetoResistance--New_Source_of_Clean_Energy/
                                      would be very funny,isn't it ?!
                                                          what ?
In 2001, Butler and Mathon independently made the theoretical prediction that tunnel magnetoresistance can reach an efficiency of several thousand percent when using the proper materials. In 2004, Parkin and Yuasa were able to make an MTJ (Magnetic Tunnel Junction) that reached over 200% TMR at room temperature. In 2009, TMR effects of up to 600% at room temperature and more than 1100% at cold temperatures were reached.
                   These percentages under R.oom T.emperature conditions ::)
                                feeding an electro-magnet
Sincerely
              OCWL
              The Joseph Yater or Dr.Helmut Reichelt Cell-array as coil wrapping the magnet core
From this article in 2011, it can be seen that the same quantum effect can be applied to the development of new solar cells which can be more than 100% efficient.http://www.nrel.gov/news/press/2011/1667.htmlThis third article from 2012 shows that LED's can also be coerced to behave in a way which is over 100% efficient.http://physics.aps.org/synopsis-for/10.1103/PhysRevLett.108.097403  In very simple terms, when most people think of alternative energy, they think of things like "solar power", "wind power", "hydroelectric energy", "thermoelectric energy", so in keeping with this spirit of simplicity, a generator which derives it energy from a magnet could be termed as either "magnet power", or "magnet energy". So, how does this "magnet energy" work?A quantum particle of solar energy is known as a "photon". A quantum particle of thermal energy is known as a "phonon". And in the same way, a quantum particle of magnetic energy is known as a "magnon". The Quantum Tunneling of electrons occurring in Magnetic Tunnel Junctions which results in the excitation of the magnons, is similar to the way a photon is responsible for the electron diffusion which occurs in the P-N Junction of a solar cell, or a phonon is responsible for the electron diffusion which occurs in the P-N Junction of a TEG (Thermal Electric Generator).
                      The "hidden" TMR-effect magnet publication,but not lost :
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=16&ND=3&adjacent=true&locale=en_EP&FT=D&date=20040226&CC=DE&NR=20317795U1&KC=U1
                                     he,Dr.Pavel Imris prefered foil
                               This  Jorge Ferreira applied on the rotor
                                                     as coil
                                 and repeating his statement
         The technical range of this system stands in the present electromagnetic spectre, nevertheless is different owing the coils not having a standard behaviour in relation to the consumption, they have not internal resistance, placing several questions of theoretical quality: According to the ohm's formula R=V/ I. With R=O and having a tension V on the coil, appear us the first theoretical difficulty to solve this equation, impossibility or irresolution. According to the Joule's formula w=I<2>xR, appears the same impossibility. According to Weber's formula Um= [psi]xRm we see that the magnetic tension (Um) is the result of the multiplication of phi ([phi]) by the reluctance (Rm) . We go on with the same impossibility. According to Lenz's formula [Delta](cos[psi])/[Delta]t we obtain that the induced electro-motive (Ei) is the result of the division of the rate of the cosine of phi ([Delta]cos[phi]) by time variation. As cosine of phi is equal to zero, the irresolution is maintained. In practice submitted to several measures and tests we obtained a residual consumption of 6 mA resulting more from cable feed then coil consumption. The value of phi ([psi]) stands unaltered and equal to zero.                 Practical situation without theoretical justification known.
                                                 Theory: TMR-Effect
                            or also identified as: the applied Biot-Savart-law Effect
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19780601&CC=DE&NR=2653497A1&KC=A1
isim
@ F_Brown
"Blue is torque on the rotor shaft.  Torque is read on the volt scale as newton meters.  Negative torque equals load on the drive motor.  Notice that the torque is mostly negative, meaning there is a lot of load transfered to the drive motor."
I use Maxwell Ansys to simulate QEG, and to me you juste misinterpreted the the torque signal.
Here a torque and speed graphe from a simution.
Notice the 0 Speed is upside left and scale for torque is right.
Note the correlation between negative acceleration and torque...
The load resistor is on the 2 "secondary's"  coils.
For me, the QEG is a simple reluctance machine, without mistery....
And yes, this machine needs something to start, noise, little voltage , little current or earth magnetic field, to start.
