0 Members and 39 Guests are viewing this topic.
Jimboot
Hey guys,
If there is no residual magnetism in the cores any other theories why the May be happening. Btwt I hit my in tact mot with a hammer and got nuttin :)
Mark:
Thanks for your comments.  As you can see, even the suggestion of a test that might somehow affect the agenda of what Gotoluc and Woopy's tests are all about is rejected by some.  Even if it makes perfect sense it is rejected in a disrespectful way.  Looking for an explanation of the phenomenon that Gotoluc and Woopy observe is rejected without wanting to even consider the merits of the test by some people.  I can only guess that it's perceived as something that may go against the wishful and idealized agenda of what the QEG is allegedly about.  That can't be permitted, or so they would like to think.  Meanwhile, some people might lose their shirts putting out the cash to just build the thing.  That's their choice, but at least some of them will want and have the right to consider and read differing opinions.
QuoteI already have the hate mail, threats lol
I admire your courage in the face of that.  One can assume that most of it is harmless.  However, one can never be sure and presume that they are all harmless.  That's why I will not reveal my name, like many other people around here.  I have received a lot of hate myself and I have at times been relentlessly bashed, demeaned, degraded and harassed.
If this whole project was launched after it had been tested and verified to work, then Hopegirl sure as hell should release the plans.  Instead, like you said, it's a new bandwagon.  Many people are already convinced that it's real.  Logic, science and just plain common sense becomes heresy indeed.
Johan_1955
Quote from: gotoluc on April 11, 2014, 06:51:17 PM
I had 2 light bulbs as load.
The limitation with my simple test design is the rotor I cores hit the E cores when resonance kicks in. This causes a braking action.
I will have to come up with a new heavier design that the rotor will not flex under resonance.
Luc
Good steps, LUC!
Maybe a try: Bring the system first to resonance, slow the loads / lamps with a rheostat to it, The lamp for lamp connecting, look his Timothy's movie again!?
Please, be very carefully with those unbalanced weight at those revolutions!!!!!!
Saver experiment is: Single-phase motor, a MOT with flux-bridge to the secondary as exciter with spark & C, primary for load but again in steps loading!
nilrehob
Im not so sure its the change in inductance that generates the voltage, but rather that the moving iron is magnitized ever so slightly and then it builds up because of the resonance, just as when you use an async (no magnets) motor with caps as a generator?
/Hob
shinz62
Quote from: gotoluc on April 11, 2014, 06:58:29 PM
Hi shinz62,
You are correct!  my design becomes a disk brake at Resonance.
I like your understanding of the possible use and work of the belt. I'll incorporate it in the next design.
Thanks for sharing
Luc
Luc
Your welcome and thank you for sharing your very exciting results too!
Your video certainly does show dramatically how just flipping the inductance can generate a large AC output. Originally I had thought that the input current on the output coils had a major effect on generating the flux to drive the high impedance LC, but you have demonstrated that is not even necessary.
However, after seeing this latest video of yours it is now obvious to me that the magnetic force is incredible across the EI core so I doubt that this EI configuration can ever work to get free energy, it is too much like a conventional generators internal magnetic resistance.
The real trick is probably more about not requiring all the flux from the magnetic path that drives the output coil to cross between a moving rotor and the output coil, but rather providing an alternate path for the huge amount magnetic force from the flux that will be generated by the high inductance LC mains as they reach resonance.
In the QEG, the lion share of the flux will be able to stay in the torroidal outer core with the rotor merely providing a way to flip the inductance back and forth between high and low to keep driving the AC resonance. The belt may play an important part by providing a little bit of slack to prevent the magnetic grab on the rotor from directly impacting the motor speed and this only needs to give for an instant as the magnetic grab should only last a partial cycle considering the 400hz AC output. It probably grabs and releases multiple times as the rotor is in close proximity with the connecting points on the outer core but the ability for the belt to provide a stretch and rebound for each grab keeps the motor from feeling it full force.[size=78%] [/size]This could explain the noise and vibration of the QEG.
Then while the rotor is free the flux path has only one way to go, through the outer core, and not across the rotor thus providing an escape clause from lenz law entirely during this portion of the cycle.
And additionally, with the main outer core providing the main path for the flux while the rotor is in close proximity and merely a secondary path, any magnetic grab on the rotor will be greatly reduced, so says Flynn, and I have verified his ideas experimentally myself.
More food for thought.
