0 Members and 81 Guests are viewing this topic.
ariovaldo
Quote from: TinselKoala on June 22, 2014, 06:03:19 PM
Here, maybe this will help.
http://www.youtube.com/watch?v=awrUxv7B-a8
http://www.youtube.com/watch?v=tiKH48EMgKE
Especially:
http://www.youtube.com/watch?v=b24jORRoxEc
The first Synchronous  motor that I installed 25 years ago was facinating. First all the rheostat was a water rheostat, using ferroform. The motor was 4.000 hp and the motor was used to correct the power factor in our plant. The trick was to get it synchronized....this kind of motor start as an asynchronous motor and we need to " excite" as soon to get the full speed....Actualy, the new version of those motors has electronic exciters and speed sensors....
Thanks for the links TK and I looked up my favourite guy for going back to basics.
When you reduce the QEG down to it's bare-bones nakedness, what is the essence of how it works?  The answer is that there is changing magnetic flux in the toroidal core, and that changing magnetic flux produces emf.  When you wrap a coil around the core, each turn in the coil picks up the induced emf. You connect a load across the coil and the emf in the coil drives a load.  In the case of the QEG the load is a bank of light bulbs.
That's what's left when you strip it down to the simplest explanation for how it works; changing magnetic flux in the core inducing emf in the coils.
That's an application of Faraday's Law.  The FTW group want you to believe that the QEG does not behave in a way that is consistent with Faraday's Law.  They want you to believe that the output from the coils is greater than what it actually is, as described by Faraday's Law.
The problem is that the QEG is the same as any other transformer, and the output will be in line with Faraday's Law.  So if there is no "magic" in terms of the coils interacting with the changing flux, then your only other option is that there is "magic" in the rotor-core interaction.  In other words the "jump" has to take place between the mechanical power supplied by the rotor and the amount of changing flux induced in the toroidal core.  Good luck with that.
Here is a back-to-basics review of Faraday's Law by a YouTuber.  You will see, that when you have changing flux in the toroid, you can calculate the value of the electric field vector at any point in 3D space around the toroid.  If you put a single turn of a coil in this electric field, it will pick up emf.   It is so well understood that it is literally impossible for the way the QEG toroid interacts with the coils to be different.  There is just no way that is going to happen.  The relationship in the QEG between the changing flux in the core and the output coils and the load will be under unity and follow Faraday's Law to the 't.'
https://www.youtube.com/watch?v=2DH7ufrkeHM
https://www.youtube.com/watch?v=de4CWQoJ684
MleHigh
ACG
Quote from: TinselKoala on June 21, 2014, 08:03:41 PM
They forgot to disable comments! (ETA: On the "Awake"radio video. Of course comments are disabled from the start on the "official" UK resonance video.)
So I left this comment, in the interests of full disclosure.
It won't last, I'm sure.
Your comment is no longer.  I am shocked.  Very little traffic on that channel so I thought it would remain longer.
ariovaldo
Quote from: TinselKoala on June 19, 2014, 08:54:17 PM
And why do you think he shouldn't post on this forum? Is there any other forum where people are telling the truth, fully, about the QEG or their work with it?
Do you think that Ariovaldo believes, or has ever believed, that the QEG device would actually ever produce OU? Perhaps we should ask _him_ just what he believes and what his intent is.
Years ago, I was diagnosed with panic attack. To control that, I started to take some strong medicines and this was killing me. To make it short, one year after the diagnosis,  I decided to get rid of medication and to help me in this process, I tried to find something to keep my mind working and at the same time, something related to my background. That is why I started to replicate everything that I thought was "different". In the last 6 years, I built so many "dumb" stuff that I'm ashamed to say here in this forum......
Now the question: If I really knew the theory behind of generators why did I  start to build the QEGt? Yes, I knew, but I tried not go so deep on that since my kids, both engineers, saw this project in the internet and bought  me the stator/rotor to see me working, testing and etc.... ( cheaper than the medicine and any ER  ;D ).
If I had stopped to think, if I had calculated the magnetic flux and if I had done the others pertinent calculus to build a normal generator, I never had started this project.
Also, you can check: I never said that the QEG works, but to me it was a very exciting equipment to be checked and the fact to need to resonate was very interesting.
Cheers
Ariovaldo
