0 Members and 88 Guests are viewing this topic.
e2matrix
Nice work TK!   I'd buy you a cheeseburger if I was in Texas ;)     So you really think it is just measurement error?   Or can't believe in OU and yourself?   LOL.    Why not try looping the output back to charge the battery and see what happens?   I dare you ...
isim
For info.
A Message To The QEG Engineers By Dave Starbuck Tuesday, Jul 1, 2014
on http://www.allegedlydave.com/blog.htm?article_id=6
ACG
Seems Dave has published a long winded article just to say sorry we have over unity but still not working under their "time limit".
Here is where its mentioned a transverter needs to be added to achieve 10kW self looping which was achieved by WITTs linking the infamous 40kW video.  Yes, the video that shows no transverter and the 2.3kW light bulb load.  WITTS could have at least filmed a demo of 40kW.  I suspect that 2.3kW was done due to mains and breaker limits.
http://hopegirl2012.wordpress.com/2014/05/30/major-breakthrough-in-free-energy-overunity-demonstrated-in-the-qeg/
Will the next hook will be crop circles and the obligatoryTesla?  For the second time, over unity being declared by Dave.   When any are to be provided are we to see the same calculation errors as we did before?
The configuration has changed many times especially with the addition of this new external windings over the core.  I would like to comment on the break down at the alleged spark gap but until an updated schematic is brought forth I would be no different than claiming over unity.  I do know that Dave should not be the one making the claims as he stated prior his math skills are as sharp as wet spaghetti and made the wrong calculations before.  Dave got smart this time, he disabled comments on this release of videos  ;)  One of which is to display a resonance cascade waveform which can not be properly viewed for analysis.
Note, he mentions having a cannabis journey where he envisioned the qeg would "sustain itself in a chain reaction that caused the QEG to explode, killing all in attendance".
isim
@TinselKoala
To answers your little power measurement problem
( http://www.overunity.com/14443/quantum-energy-generator-qeg-open-sourced-by-hopegirl/msg408251/#msg408251 )
"Meanwhile, can someone help me with my little power measurement problem? It seems that I have Overunity In Vars to an embarrassing degree right here on my workbench. Er, work _chair_.
Input: DC at 11.83 V and 2.70 A = 31.9 W
Output: 633 kHz sine wave, 68 V p-p and 21.6 A p-p, in phase, = 1469 W p-p, and divided by eight = 183.6 W
http://www.youtube.com/watch?v=wI2r85CeCaw
The purpose of this video is to deliberately illustrate some pitfalls in measurement, and also to show that having large VxI measurements on your output in a resonant and reactive system isn't unusual. I present it as a sort of exercise or quiz for contemplation. I assure you that there is no trickery, all is as presented in the video."
Your resistor(R=0.5ohm) was a wound resistor. If we suppose a diameter of 1cm, a length of 5cm and the resistive core made of 20 turns, it's inductance is 0.8uH (http://hyperphysics.phy-astr.gsu.edu/hbase/electric/indsol.html)
With a main coil made of 4 turns, a diameter 20cm and a diameter wire=1.2mm --> L=4.5uH
http://emclab.mst.edu/inductance/circular/
If you put these approximations values in LTspice we get:
  In the first plot pane the true power in the main Coil
   - In blue, abs(Vmain_coil*Itrue_resistor)
  In the second plot pane:
   - In green Voltage of the main coil= 24Vrms  --> 68Vpp
   - In red, your measure, current in the bad resistor with R=0.5ohm and inductance=0.7uH V/R=I calculed=7.346Vrms or 21Vpp
  In the third plot pane:
   - In purple, V/R=I with the true resistor R=0.5ohm L=0H  I=0.650 Arms
   - In blue, your measure, V/R=I with the bad resistor R=0.5ohm L=0.7uH  I=7.346 Arms
Note the phase between the current and the Main Coil Voltage.
The true power in the main coil is 19W.
Don't forget it's just an approximation... like my English words!
@isim:
Thanks for running that sim!
A couple of other calculations and measurements by other methods have determined that the resistor's inductance is 530-580 nH, a bit less than your value. My meter doesn't go low enough, and my function generator doesn't go high enough, to get a very precise reading on inductors below 1 microHenry!
The main coil's inductance is also much lower than your value; it is only a single loop of 3 parallel (twisted) separately insulated strands of #12 solid copper house wire, 22 cm in diameter. It is also below 1 microHenry; my meter won't read it. But I agree that the circulating power is actually in the 20-30W range.
I also don't have that much phase shift showing in my scopeshots, probably because of the lower overall inductance in my apparatus.
I'll be uploading a second test with a better current-monitoring setup later this evening.
Thanks again for your work!
