ACG
Quote from: PCB on July 05, 2014, 06:11:16 PM
I've not been banned but I have been summarily warned in a direct email to me, in response to the question asking why my posting had been deleted.  There can not be any negativity in the posts and my last one asking for explanations as to why they have not been able to successfully build a working device, given James said he had one in PA, was going just too far he said. Larry pointed to the fact that they are now in R&D mode with the goal of self looping by the end of the month. He made various mentions of trolls, bad people, but affirmed that I am not a troll, thank god!
One swift reply of "Implementing (-) Karma is in direct violation to the policy laid forth".
The be-do czars would have a fit.
ACG
Narrative update in order:
1. Output of 240v 42 amps 60hz to be easily connected to your house (from manual 03-25-2014 http://hopegirl2012.files.wordpress.com/2014/03/qeg-user-manual-3-25-14.pdf).
2. Output of 2000v 5 amps 400hz (from Taiwan interviews starting @4:40 http://www.youtube.com/watch?v=atLN-mkmqBE notice James said "if")
3. Output of 1400v at lower amps yet 200hz, and may need an aerial? (Morocco May 2014)
4. Output to be supplemented with a Markov coil + transverter to draw power from reactivity of the primary coil (United Kingdom June 2014 http://hopegirl2012.wordpress.com/2014/05/25/qeg-3rd-phase-development-self-running/).
5. UK No Go.  Return to Pennsylvania prototype.  Now classified as Research and Development.  Self runner to be completed in a month (July 4, 2014 https://twitter.com/hopegirl587/status/485162445795635200)
PCB
Quote from: ACG on July 06, 2014, 12:40:12 AM
Thank's for the timeline ACG. I'm finding it difficult to keep track of all the changes/rewrites.  The problem is they keep pushing the goal posts down the track. Now it's self looping at the end of the month. You notice that with all the fan fair leading up to the UK build, that in the UK videos there are no measurements presented, no osc waveforms, no results given for the Markov coil, really nothing to hang your hat on. Or from their perspective hang yourself by the neck.  The only solid report technically from the vid was that the QEG does not produce ionizing radiation. Really not something I would have thought to test for at 400Hz.
PCB
Getting serious for a moment. My thoughts here are inspired from reading this article:
http://globalenergytransmission.com/index.php/en/latest-news/27-examining-working-principle-of-tesla-tower
1. The QEG is a mechanically driven resonator, whereby a standing wave is created in the primary via parametric excitation.
2. The QEG is also a transformer than allows energy to be drawn off from via the secondary.
3. At resonance the primary is a "charge" or "current buffer"
In the present design there is no way for charge to be brought into the buffer, except via the parametric excitation process. So what if the primary is connected to the ground? Could the QEG be made to work like Tesla's tower?
So notes:
"Active Resistance" http://books.google.com/books?id=ejzScufwDRUC&pg=PA913&lpg=PA913&dq=lc+circuit+%22active+resistance%22+resonance&source=bl&ots=nIpCGrxWlb&sig=RF89qQnFbRWJ_j2FaOgXeKyM3ZY&hl=en&sa=X&ei=FFq5U5qgCMeQyASn14HAAg&ved=0CDoQ6AEwBA#v=onepage&q=lc%20circuit%20%22active%20resistance%22%20resonance&f=false
Taken from above article:
QuoteThe answer is simple as we have already examined working principle of the Tesla Tower. From the viewpoint of generator, Tesla Tower is not any different from some kind of external ground (connected via active resistance of the Tower). This is due to the fact that generator "sees" only active resistance of the Tower but does not react anyhow at the charge value, which is accumulated in the tower. This is because of capacitive and inductive resistance in the resonance mode compensate each other. In other words, for generator the Tower is some sort of "grounding" via resistance which is equal to active resistance of the Tower.  As it was noticed above, such charge evokes distribution of the charges in ground located in direct proximity next to the Tower. However, the higher charge integrator of the Tower is elevated the less important is that factor as capacity Earth-Ground is decreasing. It is enough to elevate charge integrator to the height which is significantly higher that the size of integrator so that the Tesla Tower would really start to serve as "external ground" for the reference generator (i.e. it is enough to minimize the capacity between the Tower and Earth so  that own isolated capacity value of the Tower would become at least somewhat equal to that of the capacity Tower-Earth)."
PCB:
In the culture of free energy you often see this notion of making a connection to a true earth ground as somehow being part of the configuration to give you a free energy device.  They talk about the ground being a "supplier of electrons" and stuff like that.  It's all foolishness.  Part of the explanation for the foolishness was about five years ago when people played with CFLs and automotive ignition coils in a "reverse configuration" where the high voltage output of the coil was connected to earth ground.  The net result was the entire test apparatus was made to bounce up and down at a high AC potential with respect to the earth ground.  With that type of setup you can touch any part of the setup with a neon light and it will glow, and it means nothing.
I am no expert on Tesla but I seem to recall reading some writings by Tesla about the Wardenclyffe tower.  He was trying to make a Morse code transmitter that could go all around the world.  So he was just trying to transmit dots and dashes that everybody could receive.  And that's the end of the story.  In my opinion everything else that you read about the tower is nothing more than untrue wild speculation that has taken on a life of its own.  It was not an attempt to transmit large scale electromagnetic energy around the world so that you could put up an antenna and power your house.  That is simply ridiculous and wrong.
The QEG and the Wardenclyffe Tower have nothing to do with each other.  Connecting the QEG to a true earth ground is meaningless.
