0 Members and 55 Guests are viewing this topic.
Quote from: MarkE on July 17, 2014, 11:00:36 PM
No, I did not hear any mention of that.
OK, thanks. I must admit I'm surprised. Is it possible that Mills might actually not know about Peter Graneau and his water arc OU claims?
PCB
Quote from: TinselKoala on July 17, 2014, 10:53:43 PM
I couldn't get through it, it made my teeth itch. Can you tell me, though: Did Mills or Sterling refer to the water-arc OU claims of Peter Graneau and Neal Graneau, as evidence for the validity of the BLP project and claims?
Very interesting. These guys use I assume high voltage and high current and pure water, and get a highly kinetic reaction. Mills on the other hand uses very high current, low voltage, and a hydrate catalyst and gets very high frequency light (little or no IR) and almost zero kinetics.  It would indeed be interesting to get Mills's take on what difference there might be in the two reactions to current. Mills also uses a microscopic amount of water, he says just the water vapor in the air is enough to power his reaction.
I did find this: http://waterarcresearch.blogspot.com/  TK you have all the components on hand to build this guys setup for sure! Just a thought, I wonder what would happen if you used a piston chamber with spark plug? Would be able to measure more accurately the energy produced by the explosion.
BeDoCuckoo
From Patrick in Taiwan
Aloha, dear FTW family and all friends and partners of active QEG CICU groups:
Today, I want to announce a very important and also wonderful update from Taiwanese QEG CICU. Our lead engineer, Mr. Li, has successfully built a mechanical overunity device prototype which has near 400% efficiency in REAL POWER: the input for drive motor is 3.7kw and the output is 15kw. This prototype can generate AC 220V in three phase and AC 127V in single phase, the current is about 58amp.
This device combines a traditional generator with a 3.7kw coupling drive motor and a set of flywheels (weight: 100kg) added on the generator. The assembling began two weeks ago, and the test run was successfully complete on July 14th. The result is very impressive: we now can load a 15kw tubular heating element in full capability while keep the drive motor running. In other words, this prototype can power every home appliance once it is tuned and hooked with the power grid.
Despite this prototype looks so fantastic, it still leaves much improvement to be done. First, it is NOT YET A SELF-RUNNING device because Mr. Li does not want to provoke too much unfriendly attention either from stubborn trolls or Taipower Company. Mr. Li also said that self-running can be achieved easily once everything is safe and sound. Second, the prototype is already too big to be categorized as a household free energy device. So we might go up the ante and develop it for community, factory, infrastructure...etc. Third, a prototype is just a prototype. Improvements like electro-mechanic control and also safety mechanism will take some time, probably few more weeks. Also, we have to discuss when and how its building instruction can be opensourced to other FTW CICUs around the world. So stay with us and keep your fingers crossed.
Finally, Mr. Li wants to appreciate FTW family for your altruistic effort and consistent support. Although this device does not go with resonance or quantum energy, it is your hands-on training program that inspires him and then comes up with such ground-breaking achievement.
ACG
Quote from: BeDoCuckoo on July 18, 2014, 11:34:29 AM
A few questions:
Now word from Taiwan has surfaced.  Why now and none before?
Is this admittance Taiwan dropped the qeg project?
Will the Taiwan group under Mr. Li change their group name to something more appropriate of the device since its admitted not to involve quantum?
This device as described has been dubbed by PES Network (peswiki.com) as a QMoGen without the Q (self looping).  What separates this MoGen from all the other claims?
Are there any publishing data, videos, reports, blogs, other than this 3rd party "Patrick" post in this forum?  Can we be informed directly from Mr. Li?
Inarguably, self-running is the prime directive for a qmogen.  I do not understand how if self-running can be easily achieved but at the same time Mr. Li gives self-running a back seat to avoid criticism of "stubborn trolls".  Volitional preclusion a desired result to avoid suppression is a case of self fulfilling prophecy.  Why not ignore the critics while building the device as intended.  Better yet, why inform anyone at all and simply use the device for your enjoyment.  That way any suppressors would not get wind of the device.  Come to think of it, you BeDoCuckoo and Patrick are taking a big risk with this notification posted here.
