Farmhand
If varying the inductance parameter is all that is required then it can be done without any rotor and with a very small input power. If I take an off the shelf 220 to 15 v transformer that has two 15 volt windings then simply short one of the 15 volt windings the inductance of the 220 volt winding varies from 4.4 H to almost nothing, then if I use a 12 volt bulb with a cold resistance of 5.5 ohms it varies between 4.4 H and 200 mH. Will that excite the transformer if I switch a load in and out at the correct frequency ? I think there is more to it than just varying the inductance, something missing, which is I think input.
QEG report from Germany. He has had his for over a year so it must be Witts device.
Looking at the report below it seems like they don't understand why they can't turn the several thousand watts of oscillating power (accumulated) in the tank into a continuous output. It's comical. Grasping at straws when they resort to the old line of
Quote"I think it has overunity potential because no matter what you attach to the output ,the QEG draws not more power."
On the other hand that behavior says to me that the output is limited to a bit less than the unloaded input.
From peswiki - http://peswiki.com/index.php/Free_Energy_Blog:2014:04:10#German_Group_achieves_QEG_resonance
Quote5kV @ 500mA
Somebody built a QEG in Germany and now has resonance.
In fact he writes in the comments that he has been tuning this machine for about a year and also gave up several times, but then with the Plans from Hopegirl he could bring the machine to work.
"A test 3 days ago showed up that we have 9300V at 0.7A. The Problem is somewhere in the Transformation between primary windings and secondary windings. If we start with a higher load attached like 500 Watt lamps we reach resonance but the lamp didn't light up. The machine is producing "raw power".
I think it has overunity potential because no matter what you attach to the output ,the QEG draws not more power. The secret is to get the exciter tank circuit to run properly, only then we can have more power than 150 Watts. Its like in Taiwan they havn't attached more than two bulbs right? Its the same here. Only raw power!"
kajunkreations
 Hey Farmhand, you are correct, the germans QEG is a WITTS device. If you go to his forum at http://www.qeg-forum.de/, you will find a little more info there.
His screen name is TeslaTech. You must register to see any images in the post.. In the thread "Construction" he says that he got his info from Tim Thrapp via Skype, but obviously not all the info needed.
Nolan
Magluvin
Quote from: gotoluc on April 12, 2014, 10:11:03 PM
Hi everyone,
the suggestion of having the bulbs in series on the high voltage side has helped stabilize the Resonance.
Here is the video demo: https://www.youtube.com/watch?v=R-jYPDuueY0
Luc
Do you have any more bulbs to add in series? ;D
Mags
jbignes5
Quote from: Farmhand on April 13, 2014, 09:49:56 AM
Farmhand,
The inductances have only a part in the whole machine. What they are saying is the high voltage comes from the Steel as a piezo type effect. Don't know if I agree but that is the source of the voltage. The coils then boost that voltage. The switching of the inductances only is used to route the voltage after it is picked up and is a guide for magnetic forces after the process starts.. Of course after the magnetics start shortcutting and cutting the coil it runs in resonance. The extra generation is from the magnetic field being channeled into the rotor then going into various portions of the toroid. But I will have to look at it way more closely to understand the basic function.
This is very familiar isn't it Farmhand? The only difference I can see from this and my angle is that they don't have a central Coil on the rotor to pull off Current from the magnetic portion of the device that travels along the rotor. Oh wait the system I was looking at uses two phases and is actively driven from a magneto. With the prime mover already integrated into this system you won't have switching problems like they are having.
